So I am rewiring my parker audio 98's to be 8 ohm loads. For those of you that are not familiar with the speakers, they are an MTM arrangement. The two 4 ohm 93db/w/m woofers are run as wideband drivers without crossovers. A FT17 covers the top with a simple 2uF cap making a first order crossover. When they are wired for 2 ohms, the tweet matches the woofers without any padding. Now that I have the drivers wired in series, the tweet is about 2.5db more efficient then the woofers. Using an l-pad calc it looks like I need a 2ohm in series and a 24 ohm resister in parallel. Considering how simple this setup is, can I just use a 2.7 ohm resistor in series and call it a day?
#2 |
Am i on the right track?
#3 |
Consider that the 24 Ω parallel acts also as impedance peak flattening
#4 |
The graph here http://www.madisound.com/loudspeaker...ions/ft17h.pdf doesn't show much of a peak. Still worth putting the shunt in?
How important is the quality of the shunt transistor? can I use sand cast or should I get something better? |
#5 |
It won't be possible to get an identical response to the original whether you use a single series resistor, a standard L-pad or if you were to go with a lower value of shunt resistor for the flattest impedance although there shouldn't be much in it. You should probably try the standard L-pad and assume you'll need to tweak it from there, unless you want to take it to measurements.
The sand cast resistors should be fine. |
#6 |
Would ARTA + and ECM8000 be good enough for measurement?
#7 |
I would think so.
| 8ohm resistor in series with 8ohm speakers for a 16ohm OT? | Reidy- | Tubes / Valves | 8 | 10th January 2010 11:25 PM |
| FS: Vintage, NOS Lafayette SK-98's (Full Range) | mrdon | Swap Meet | 2 | 5th July 2006 12:07 AM |
| Cabinets for Vintage Full Range Lafayette SK-98's | mrdon | Full Range | 2 | 19th June 2006 10:04 AM |
| math/science help re Henry W Parker | moray james | Planars & Exotics | 4 | 1st April 2005 01:00 AM |
| Parker Audio 98 kit - Great for the money | DJNUBZ | Multi-Way | 0 | 4th March 2005 07:55 PM |
