Box rattles only at 99, 100, and 101hz sine wave - diyAudio
Old 30th April 2012, 09:01 PM   #1
Default Box rattles only at 99, 100, and 101hz sine wave
My 2 way makes a fairly loud "rattling" at around 100hz, in which I think it is somehow rattling the horn. The woofer and horn are in separate chambers separated by 3/4" mdf. Is horn rattle the likely culprit? I can't tell by listening. This ONLY happens at 99, 100, and 101 hz. 98 and below there is no rattle and 102 and above there is no rattle. Will adding polyfill help with this?
Old 30th April 2012, 09:33 PM   #2
neutron7's Avatar
Maybe something is loose in there, or a wire touching something?
I always like to check fore the simplest things first.
Old 30th April 2012, 10:24 PM   #3
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Have you tried taking the woofer out and playing it free air? I've seen lead in wires rattle against the cone. Also, try taking the tweeter out and playing the tone to see if it's the tweeter.
Scott
Old 30th April 2012, 10:27 PM   #4
Have you used a sealant/adhesive behind the horn mount flange?
I've had bad glue between magnet and basket on those woofers. I've had bad glue (missing) at the surround too.
It is difficult to make Certain the flanges of those freaky woofer baskets are not leaky and buzzing without filling the entire cavity underneath with your favorite kind of congealing/hardening goo.
Old 30th April 2012, 11:32 PM   #5
speaker dave's Avatar
Its just as likely that the woofer and baffle are at resonance at that frequency. Get the system rattling and very lightly touch the various surfaces. If it is a cabinet surface in resonance you can't do much about it without serious bracing or modifications. Even if it vibrates, it shouldn't rattle. It might be something internal such as the crossover or some wiring that is actually rattling. With luck you might be ablr to reposition the offending bit or tie it down.
matching sine wave wave file / expert opinion Sanon Analog Line Level 0 10th February 2012 03:57 PM
Sine Wave Generator with bulbs (Sine-lightenment) Rodeodave Everything Else 6 21st July 2008 12:19 PM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Copyright 1999-2017 diyAudio
