#11 |
What's wrong with the 913? It is one of the best performing tweeters that you can get regardless of price.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#12 |
Probably nothing, but I would prefere something with a more even response. I know that it is the point of diminishing returns, but if I can squeeze a bit more then why not.. I do think that that on some tracks though that there is something missing which makes me curious (since this thread) if the crossover has be reworked since Wilmslow moved from using the Vifa tweeters over to the 913, because after what you guys have said if the cross over was originally designed for the vifa, then using what they supplied me with (the 913) would be a bit rolled off would it not?
When I originally spoke to Wilmslow when I blew the tweeter he remembered when I bought them, but still asked what tweeters I had as he said they supply a few different tweeters for the k100s and I doubt the crossovers that come direct fom ATC are altered for sure. Soo I am thinking that if the Vifas were the original of the design, then the 9500 would going on the numbers be balanced like mine (I dont know just what I understand ). So if the vifas are what the crossover should see, then how would the 4662000 measure up now?Regards CL |
#13 |
Very hard work reading this TBH. But replacing a ferrofluid tweter with a non-ferrofluid type is a complete redesign! Different considerations altogether. Ferrofluid types can get away with second order, non-FF prefer 3rd order.
Mate, you should just replace like with like, Scanspeak Discovery D2608/9130.00, looks a good one to me: Scanspeak Discovery D2608 9130 00 You may have some opions to adjust level and slope without mucking up the phase too much, but that depends on your crossover, which you should analyse. An input resistor to the HF filter can generally be changed without too much harm as long as you know what it does to top end impedance, but everything else like Zobels and pads at tweeter end is select on test!
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK. |
#14 |
If you could find impedance and frequency curves for your old tweets, you might be able to find something that emulates it. Then make sure the new tweets Fs is the same or lower than the old tweets. If you can manage all of that, it might sound ok.
You could just throw something in there, cross your fingers, and have a few resistors on hand to match the output. Not recommended to someone else, but have done this for myself in non critical 2nd components (computer speakers). Last edited by jim1961; 29th April 2012 at 10:01 PM. |
#15 | |
Regards CL |
| A pair Seas 4 ohm tweeter used by B&O | gaborbela | Swap Meet | 4 | 10th December 2012 02:10 PM |
| Replacing 8-ohm tweeter with 4-ohm | Zigakly | Multi-Way | 8 | 22nd September 2009 09:59 PM |
| better 4 ohm tweeter than the Vifa MG27? | centaurus3200 | Multi-Way | 0 | 1st March 2007 05:17 PM |
| 4 Ohm woofer 8 Ohm tweeter | Tennessee Jed | Multi-Way | 4 | 22nd April 2006 12:13 PM |
| Will 6 ohm tweeter work properly with 8 ohm components? | dih1118 | Multi-Way | 7 | 21st September 2003 12:18 AM |
