Old 27th April 2012, 01:30 AM   #1
fakeout is offline fakeout  Canada
fakeout's Avatar
Arrow HiVi L5-8R VS Dayton Audio DC130 (with FR)
I got information from Solen.ca on the Veravox 3X that I bought. They told me it's the same as the Omnes Audio BB3.AL. Anyway, here are the specs (translated partly thanks to a German poster here):
Veravox 3
Impendance: 8 Ohm
DC resistance (RE): 5.4 Ohm
Resonance Frequency: (FS) 107 Hz
Mechanical damping (Qms): 7.24
Electrical damping (Qes): 1.0
Free air total damping (Qts): 0.88
Equivalent air volume (Vas): 1.11
Moving mass: 2.5 g
Suspension stiffness: 0.89 mm/N
Mechanical loss: 0.2 kg/s
Effective cone surface (Sd): 28 cm^2
Power factor (Bxl): 3 N/A
Voice coil inductance (Le): 0.17 mH
Voice coil: 24 mm/ 4 mm
Cone displacement: + - 1 mm
Outside diameter: 79 x 79 mm
Inner diameter: 69 mm
Depth: 40 mm
Flange thickness: 2 mm
Anyway, I wanted to pair these Veravox 3X full range drivers with woofers so I could unload the bass movements from the FRs.
So, does anyone think I might need to go with 6-1/2" woofers instead? I was thinking of either the HiVi L5-8R or Dayton Audio DC130 5 inchers partly because they would probably fit better on my desk (in desktop enclosures).
Feeling Good by David Burns
Old 27th April 2012, 03:06 AM   #2
I put those numbers into Unibox to find the efficiency: 85dB @2.83v/1m
ideally your woofer will need to match (or slightly exceed) that.
How big a woofer you use depends on: how large a box you can put up with, how low you want the woofer to go. I suggest you put the parameters of the two drivers you mention into Unibox and see how they will perform.
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
DAYTON 8" FR PS220 Discussion bear Full Range 95 26th August 2012 12:27 AM
What´s happening with Dayton and HiVi? Wargreymon Multi-Way 1 24th March 2011 08:04 PM
Finally finished 3-Way Dayton/HiVi/Visaton setup Psychobiker Multi-Way 4 20th October 2010 03:29 AM
FS: Dayton sub 1200, Eminence sub, Seas mid-bass, HiVi, ATD, Axon ccz Swap Meet 3 17th August 2010 08:54 PM
doing surgury on a Kicker l5 skooter Car Audio 6 30th October 2008 01:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
