Old 25th April 2012, 01:52 PM   #1
Starre is offline Starre  Sweden
Default Fullrange with 10 inch woofer?
Is it possible to make a good speaker with a 10 inch woofer combined with a full range unit? The goal is to reach 20Hz with that woofer and avoiding a 3-way using a full range unit on top. It will hopefully make the crossover easier, only one crossing point needed.
Old 25th April 2012, 01:58 PM   #2
DrDyna is offline DrDyna  United States
DrDyna's Avatar
That's essentially a FAST system, it's been done quite a few times.
Markaudio fullrange + Woofer 6 (FAST)
Tang Band full range & subwoofer two way? - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com
Old 25th April 2012, 01:59 PM   #3
Speakerholic
Cal Weldon's Avatar
Yes there are many similar systems but...
...do you really need 20Hz?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 25th April 2012, 02:10 PM   #4
Who doesn´t need 20Hz , would be nice!
Old 25th April 2012, 02:32 PM   #5
Thank for the links, I will have a look.
Old 25th April 2012, 05:10 PM   #6
Inductor's Avatar
Find the FR yourself. There are many available including the experiences with "Das Viech" with the Beyma 8AG/N full range driver of bubuxxl@diyAudio
Visaton Stella - any thoughts?
Strassacker: Speaker - kits - do it yourself
http://profesional.beyma.com/ingles/...0_FULL%20RANGE
Then you only need a good woofer to go to 19/20 Hz with a 90/100 Liters enclosure for that purpose, no problem. Also look at what is your objective in terms of SPL of the FR.
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
Black Dahlia Acoustics - Loudspeaker Kit Plans
Large bande Fostex FE206E - 20cm
Large bande 9cm TangBand W3-316B (8Ohm)
full range Fostex FE103E
Tang Band W8-1772 8" Full Range Driver - YouTube
FaitalPRO - Professional Loudspeakers Made in Italy
Old 25th April 2012, 05:13 PM   #7
frugal-phile(tm)
planet10's Avatar
Another thread on the subject -- it will lead you to 3 more eventually.
A thread for Tysen and variations on FAST
I'm currently listening to such a system. EL70eN + 2 x EL166 per side.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th April 2012, 05:45 PM   #8
Inductor's Avatar
More info on FR (sorry about the German site, you can always use google/translate).
Hi-Fi Audio Drivers - Transducers (Speakers and Tweeters) for DIY
FullRangeDriver.com
News bei SpectrumAudio-Spezialvertrieb für Breitbandlautsprecher und mehr
Old 25th April 2012, 08:58 PM   #9
Thanks planet10 and Inductor, I think the answer to my question is a "yes" without hesitation.
Old 25th April 2012, 10:47 PM   #10
fakeout is offline fakeout  Canada
fakeout's Avatar
I'm not the expert, but my only concern would be when I read the following:
"The only negative aspect i've found is that an underhung fullrange driver has usually an even smaller voicecoil than a typical 1" dome has, and no ferrofluid to cool it. So you get thermal compression problems pretty early on, especially combined with low efficiency."
I'm still debating whether I should add woofers to a pair of full rangers I have.
Feeling Good by David Burns
Coral Flat-10 (Beta Look-Alike) 10" Fullrange Drivers thetubeguy1954 Full Range 37 20th August 2011 11:47 AM
Audio Technology 10 inch woofer question domtweaker Multi-Way 3 13th July 2011 03:42 PM
2way Studio monitor with 10 inch woofer help rhythmdiy Multi-Way 5 17th December 2008 12:56 PM
JL W3v3 10-inch or 12-inch? bad1301forlife Subwoofers 1 1st April 2007 09:05 AM
Snell replacement 10 inch woofer hollytone22 Multi-Way 5 26th March 2005 06:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
