Old 26th April 2012, 01:25 PM   #21
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I don't see why it's difficult to get down into the 20s, even with a passive subwoofer. I've got a couple of Peerless 831759s here in my old corner loader cabinets that'll happily play down into the low 20s and sound great even with modest power and a simple iron core inductor and parallel cap crossover.
I'd say get a couple of these: Dayton Audio RS270-8 10" Reference Woofer 295-357
Work up a pair of boxes that your FR cabinets can sit on. Tune it down around 25 cycles or so and cross over passively to your full range at 80 - 90 cycles, or even MiniDSP it. Done.
Old 26th April 2012, 01:46 PM   #22
Josephjcole's Avatar
80Hz seems pretty low for a passive crossover. Pretty close to the resonant frequency of the full range driver. I've got a 4" full range driver that I crossed over passively at 300Hz. Even at 300Hz I could still measure some peaking around the resonant frequency. Putting a resistor across the terminals of the full range driver helped to some extent...
Old 26th April 2012, 02:02 PM   #23
kipman725's Avatar
Send a message via MSN to kipman725
There are ways of getting around room nodes such as the double bass array:
Double Bass Array (DBA) - The modern bass concept! - AVS Forum
I had a think about this and 2 feet of fiber glass on one wall and and an array on the other wall should work almost as well while reducing the cost, might cause damp problems though.
Passive crossovers are not ideal for a low crossover for a full range as you will need to compensate for the impedance peak of the driver. Unfortunatly the magnitude and frequancy of this peak will change at high drive levels and as such you crossovers characteristics will change!
*also the system in my sig is a full range with subs system that works pretty well although I have room node issues due to the enforced maximaly coupled position of my subs.
CHR-70+Subs
Old 26th April 2012, 02:27 PM   #24
DrDyna's Avatar
Well, that's just the number I have in my head because I was thinking of doing some kind of FAST system using the Markaudio Alp12 once the new generation is out and that'd be safe to use down that low.
I suppose if you're using an eensie weensie full range driver that won't play lower than a midrange then yeah.
Old 26th April 2012, 02:35 PM   #25
DrDyna's Avatar
I started reading that article and it seemed very interesting, until a little further down in the thread, I read this:
"A time ago I used closed boxes. But since there is no room gain with a DBA (you practically get free air conditions) I had to use a +12 dB shelving filter in the lower end. This dropped max SPL a lot, because of high cone excursion. So right now all subwoofers are vented designs."
Old 26th April 2012, 03:39 PM   #26
kipman725's Avatar
no free lunch if your fully absorbing the reflected wave the room is not there so no room gain.
CHR-70+Subs
Old 26th April 2012, 04:37 PM   #27
Swifty is offline Swifty  Netherlands
Actually, I am doing exactly what you are contemplating. I am now in the process of optimising the filter. I can already say with confidence however that this combinaton is working very well. I must say that without active DSP filtering this would be a lot more complicated to get right.
Old 26th April 2012, 05:12 PM   #28
DrDyna's Avatar
Very, very nice, almost exactly what I was going to try, with slightly different drivers.
Old 26th April 2012, 10:06 PM   #29
I'm not talking about running out of excursion... I talking about dealing with the spike in impedance near Fs. Like you mentioned a MiniDSP is definitely the way to go. Trying to crossover around 80Hz passively would be problematic at best...
Old 26th April 2012, 11:30 PM   #30
Inductor's Avatar
Yes, problematic but for a passive crossover you have to identify the best type of crossover to have a phase match between the two drivers. That's where only some (diyAudio members) can go. And at the same time identify the problems that you address very well of the capacitance of the crossover filter (cap) with the inductance of the coil of the driver (that's going to resonate) together with the natural resonance frequency of the driver, and we don't have a horn here so we don't have to deal with that too. Solve all this problems and you are set for a passive system. Plus, you have to know what is the driver you are going to use as woofer/sub, because you need extension and at the same time a lot of (90>) SPL. So that's why I say choose your (FR) full range first and then you are half way to solve the puzzle.
Coral Flat-10 (Beta Look-Alike) 10" Fullrange Drivers thetubeguy1954 Full Range 37 20th August 2011 11:47 AM
Audio Technology 10 inch woofer question domtweaker Multi-Way 3 13th July 2011 03:42 PM
2way Studio monitor with 10 inch woofer help rhythmdiy Multi-Way 5 17th December 2008 12:56 PM
JL W3v3 10-inch or 12-inch? bad1301forlife Subwoofers 1 1st April 2007 09:05 AM
Snell replacement 10 inch woofer hollytone22 Multi-Way 5 26th March 2005 06:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
