Old 24th April 2012, 09:15 PM   #1
diypass is offline diypass  Italy
Default Crossover bypass capacitors do really matters ?
what are your opinions ?
thank you
Old 25th April 2012, 03:00 AM   #2
dlp4341 is offline dlp4341  United States
diypass
The following is from AK
02-12-2012, 02:07 PM
dlp4341
AK Member
Qwin
I did a test to see if I could hear any difference with or w/out Vershay 0.01 bypass caps. I wanted a fair test , so I used the same speaker and XOver and used relays to add or delete the 0.01 caps. This way I could AB switch the caps in / out and eliminate most of the extraineus variables. We ( an EE and long time HiFi nut, a Musican and I) listened to varous CDs an could NOT hear a difference.
In retrospect the XO we used had all new to one year old caps from PE.
Some were 1% Daytons, others Solons. Most were actually made up two caps to get the desired value. Eg 7.27=6.8+0.47. So is the smaller 0.47 cap acting as a bypass? Or are Daytons and Solons so good they dont need bypassing?
You maybe interested in the time delay issues with coaxiel speakers.
http://web.me.com/donaldpatten
Old 25th April 2012, 03:13 AM   #3
DavidL is offline DavidL  United States
DavidL's Avatar
thank you
Opinions about THAT subject will probably end up covering about 10 to 20 pages of posts on here before it finally fizzles out.
MY opinion is that they aren't needed as long as the capacitor being used meets its specifications as to capacitance, has low enough ESR and is rated at a high enough voltage. Some like electrolytics, others prefer film caps (mylar/polypropelyne) of moderately more price while others only use the very pricey boutique caps.
Being as how film caps are not that pricey and very stable over time and temperature I use those.
If you do feel better using a bypass cap, then by all means do so, making sure the combined caps meet your design goals. It won't hurt anything if you do.
Old 26th April 2012, 12:25 AM   #4
Inductor's Avatar
thank you
My guess is you can do it. Post your results if testing.
JBL - Bypassed Capacitors & Biased capacitors
Bypassed and Biased Capacitors
Old 26th April 2012, 01:43 AM   #5
jcx is offline jcx  United States
you could try puting some # on the table
capacitor bypassing/cascading......
Old 28th April 2012, 04:36 AM   #6
irext is offline irext  Australia
irext's Avatar
I recently built a pair of Joe Rasmussens Elsinore's and used Solen SCR caps for the HF filter series pass element. I listened to them for about 5 months then changed to Jantzen Superior Z caps. The difference was remarkable. Much greater detail and subtlety. I didn't think the difference would be very great or even audible at all but I was somewhat gob smacked. I have always been very sceptical of bold claims made by esoteric manufacturers but in this instance they were right on the money. Well worth the expense. (About $12 Aus ea)
Bypass capacitors in cd players 210 Digital Source 18 29th January 2011 07:48 PM
Bypass capacitors on diodes? wwenze Power Supplies 7 5th December 2008 12:23 AM
bypass capacitors jitter Digital Line Level 2 23rd November 2008 08:21 AM
Bypass Capacitors noodle_snacks Multi-Way 37 27th October 2006 01:41 AM
bypass capacitors sourcing omni Parts 0 16th July 2006 04:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
