Hi eveyone,
I'm having a bit of an experiment. I currently have some fugel horns with fostex fe126en drivers. I want to boost the bass a bit, not a lot, I live in flats and swmbo won't allow wall shakers so I want to use some Monacor drivers that I have. Monacor SPH-135C Now, you'll probably say I won't get as good results as I could but this is a learning exercise too so I'm happy to compromise but, I'd like to build a two way bass reflex sized box, one that can eventually take a tweeter as I evetually want to build some two way speakers too and have a play with those. Another reason for this is that I have some gorgeous oak speaker stands which are sulking and I want to put them back into use too. So, what kind/style of cabinet could I use, capacity, approx dimensions etc? Also, crossovers? |
#2 |
I should add, if the bass reflex idea is real no go I did consider building the Rogers AB1 bass extender style enclosures used with the BBC ls3/5a speakers, god/bad idea?
#3 |
a box around 16 L tuned to 40-42 hz should suit these drivers;
however they are ~5dB less sensitive than the FE126's, either bi-amp or use 2 monacors per side You may find this thread useful: Help! Monacor sph 135C xover
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
| advice on a 15" or 18" DIY subwoofer build | AndyAudio | Subwoofers | 6 | 12th November 2011 08:07 PM |
| Advice on first DIY speaker build | Williham | Multi-Way | 17 | 29th April 2011 09:42 PM |
| Need some advice/help on a two way build. | Boscoe | Multi-Way | 5 | 28th March 2011 10:01 PM |
| Need some build advice... | Boscoe | Multi-Way | 0 | 7th December 2010 06:49 PM |
| Looking for some build advice | JPeitzman | Tubes / Valves | 8 | 8th June 2010 05:10 PM |
