midrange recomendations - diyAudio
Old 22nd April 2012, 01:15 PM   #1
tvrgeek is offline tvrgeek  United States
Default midrange recomendations
I have not really followed midrange advances as I too have been misguided by the 6"- 1" expected current trend. I have reason to believe there are serious issues here so am looking for a 500 to 5K midrange of very low distortion and flat enough as to not require multiple networks to tame it. My goal is to keep the really high energy 2K to 4K out of the tweeter. Any thoughts on preferred drivers?
Old 22nd April 2012, 01:46 PM   #2
Face is offline Face  United States
Face's Avatar
Scanspeak 10F.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 22nd April 2012, 02:05 PM   #3
That one did catch my eye, along with the Seas Prestige FU10RB-H1600-08 and Tang Band W3-1318SA and Mark 3.5". I have had no experience with any of them.
Old 22nd April 2012, 03:06 PM   #4
Inductor's Avatar
Eton 4-200/A8 Symphony, 4" Mid/Bass also a good candidate
Eton 4-200/A8 Symphony, 4" Mid/Bass with Aluminum Former: Madisound Speaker Store
as the Audax HM130Z0
Haut parleur medium 130 cm Audax HM130Z0
A lot of members are not going to answer you because they don't know the context (use/SPL, freq. crossover/tweeter...), sorry fst.
Help me select a mid
Old 22nd April 2012, 06:15 PM   #5
Michael Chua's Avatar
Default VIFA D75MX 3" Fabic Dome
I think it's no longer in production. I'm crossing it at 700Hz to the 8" Usher and 4K to the Vifa XT25. Running it 3-way active.
ampslab
Old 22nd April 2012, 06:20 PM   #6
diyAudio Member RIP
It refuses to die :
ScanSpeak Discovery D7608/9200-10 3" Dome Midrange (D75MX41): Madisound Speaker Store
Been made for donkies years.
http://www.parts-express.com/pdf/264-550.pdf
rgds, /sreten.
The off axis dip is a phase related issue, so off axis is fairly smooth.
Old 22nd April 2012, 10:09 PM   #7
Face's Avatar
I would not use that down to 500hz.
Old 23rd April 2012, 12:14 AM   #8
The primary issue with the 6-inch 2-way is the polar response, although there are some that do well on a whole (IE many of Jeff Bagby's designs, or something with a waveguide on the tweeter).
Trying to avoid a crossover in that passband only opens you up to other issues. I don't consider it particularily good design to be trying to cross a tweeter over near 5khz... no midrange will realistically cover that bandwidth as well as you expect. If I had to make any suggestions though, it would be the EJ Jordan JX92S or the CSS VWR125 for less expensive drivers, and the Scanspeak 12MU and ATC 150 for pricy high end drivers......... But it would not be my suggested plan of action. It's essentially backwards design philosophy.
Unless you need PA SPLs, the better domes IE CSS LD25X, SB29, Usher 9950, RAAL 70-20XR, CSS Planar 2, Beyma TPL, or Dayton RS28A, will play earbleedingly loud without meaningful audible distortion crossed in the 2khz range and some even lower than that. So your logic really fails me.
And then there's compression drivers, if you do want limitless dynamics. Also good 1" compression drivers in good waveguides covering 1khz on up will sound better than wide bandwidth mids with a crossover at 4khz to a tweeter.
Old 23rd April 2012, 12:54 AM   #9
Einric is offline Einric  United States
Einric's Avatar
I would recommend the Alpair-6P w/ SEAS K2851 chamber behind it.
I have heard some very good things about Mark Audio drivers.
In the SEAS chamber it appears to be nice and flat to 250hz or so.
The Alpair 6 should be give all the upper midrange you need to safely cross to your chosen tweeter.
On the downside is the 86db sensitivity.
Old 23rd April 2012, 01:24 AM   #10
You're right. Eventhough Vifa recommends 500Hz, it didn't work for me. The D75MX sounded strained. And that is with 24dB/oct slope. Moved it up to 700Hz and it cleared up.
ampslab
recomendations please falcoron Full Range 3 26th July 2011 01:19 AM
Recomendations on build tvrgeek Solid State 2 24th January 2010 02:24 PM
Need recomendations for 3-5" midrange driver? Big_Bill Multi-Way 127 1st July 2009 02:23 AM
Amp recomendations skooter Car Audio 10 3rd November 2007 05:13 AM
Speaker recomendations Konnan101 Multi-Way 3 2nd January 2004 08:01 PM
Copyright 1999-2017 diyAudio
