Old 19th April 2012, 03:40 AM   #1
Default Anybookshelf Full range speaker close to Totem mani-2
I really want to build a True full range bookshelf speaker which can go to lower 20 min 25hz minimum...if it is possible...
Mostly i am trying to replicate the sound from i have Totem mani-2 full range bookshelf speaker ....
is there any already DIY design out there....which can help for this....
any help or direction is much appreciated....
I recently had those and they have beaten some full range speaker i had... i am kinda biased with speaker without needing the sub....
Old 19th April 2012, 05:33 AM   #2
frugal-phile(tm)
planet10's Avatar
What full range speakers have you had?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th April 2012, 06:34 AM   #3
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
I want to give Satori MW16P (bloody pricey indeed) a shot.
Despite being marketed as a woofer, the frequency response (on and off axis) are pretty extended. Just add a super tweeter will do. No, it can't do the lowest octave on a bass reflex, but a rear loading horn or transmission line? I don't know...
Old 19th April 2012, 07:53 AM   #4
thisisvv:
If you want a bookshelf speaker with relatively deep bass, then you need to look for low sensitivity speakers and not play them too loud.
Some MarkAudio or Tangband will do that.
When you write: "which can go to lower 20 min 25hz minimum...if it is possible..." it depends on how loud you want this bass relative to the loudness of the other frequencies. At full strength or even at -3db it will be very, very difficult to find FR units that can do this in a small box (even in a big box it is difficult). And the excursion of the cone when rendering deep bass may well muddle the general sound.
borispm:
That Satori MW16P (bloody pricey indeed) is indeed quite interesting at first (2nd) sight...
Old 19th April 2012, 01:13 PM   #5
I don't think the OP is talking about full range as a single driver speaker, but rather as 20-20k w/o subwoofer.
The Mani-2s are spec'd 29-20k +/- 3 dB.
The Mani-2s are two way speakers. Wrong forum.
I was so much older then, I'm younger than that now.
Old 19th April 2012, 01:54 PM   #6
I apologize if it is posted in wrong forum....i will take my query to right forum...i just wanted a small bookshelf that can go low and giving a life like sound....
Old 19th April 2012, 02:11 PM   #7
dave
I have Gershman Acoustics...listened to Totem Forest...
On DIY this is my first project...and i am still learning about Sound still.
Old 19th April 2012, 03:34 PM   #8
frugal-phile(tm)
planet10's Avatar
moved to multi-way
dave
Old 19th April 2012, 10:55 PM   #9
The mani-2's use isobaric loading like the old Linn Sara's.
Short answer is I don't know any current diy design with really serious bass.
Not in a small form factor, small bookshelf kind of way. An old design :
Extremis
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 20th April 2012, 03:13 AM   #10
Extremis
rgds, sreten.
Thanks seems he is saying that the midrange needs to be changed a little...will look around..
somehow amazed that there is no DIY for this simple requirement.
Full range active speaker zebra100 Full Range 10 24th August 2009 11:28 AM
Fertin Full Range Speaker Cherel Full Range 29 5th January 2009 10:31 AM
full-range speaker problem nandax Full Range 0 9th December 2008 07:30 AM
Technics Full Range Speaker HKC Full Range 0 5th June 2006 01:33 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 07:38 PM
Page generated in 0.63580 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
