#21 |
This combination of drivers seems to be screaming out for different amplifiers.
I see little point in creating an 8ohm passive crossover for two drivers that are so mismatched by such an amount. |
#22 | |
Speakerholic
![]() Fusion, you have a lot of persons here trying to help you. Good idea to listen to them. Andrew's post seems to make the most sense at this point. |
#23 | |
That doesn't make any sense. It might if you wanted to run the treble off a flea powered class A valve amplifier which it does allow you to do. Otherwise the tweeter sensitivity makes no difference to the arguments regarding active and passive x/o's. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#24 |
It makes some sense to me.
Where did active come from? I never mentioned it. |
#25 | |
"I see little point in creating an 8ohm passive crossover" implies using an active x/o instead. What some sense ? rgds, sreten. It it was me building the "Standard Econowave" I would redesign the treble x/o section for higher load impedance than 8 ohm, say 22R, and put most of the attenuation at the front end of the x/o, meaning low power handling requirements for the rest of the components. A way of using to advantage, the high tweeter efficiency.
#26 | |
#27 | |
I don't understand the question. What I mean is if you know your going to attenuate a mid / tweeter a lot, doing it between the x/o and driver with a high power 8R L-pad is not the best way to do it. rgds, sreten.
#29 |
I don't get the down side of excessive tweeter sensitivity. Sreten suggests a better way to deal with this potential advantage.
| Driving 8 Ohm Speaker | bikerbiker | Solid State | 8 | 12th November 2008 09:08 PM |
| how to use the correct speaker for car? | 2fast | Car Audio | 9 | 21st June 2005 02:58 PM |
| Can you use a 8 ohm crossover with 4 ohm speaker? | Bull | Subwoofers | 1 | 19th May 2005 08:37 PM |
| 6 ohm speaker 8 ohm amp | EDAT | Multi-Way | 7 | 15th January 2004 08:19 PM |
