Hello everyone again!
Now, I have google searched after google search but cannot find any definite links or circuit diagrams to help. I currently need to shape the response of a compression driver a little. It needs around 3.5dB taken off 3.5K, 1.5 BW/Oct (Or thereabouts). Current crossover is a 24dB/oct 1K35. Can anyone give me a helping hand? Even a point in the right direction would be great! ![]() Many thanks, |
#2 |
Use Series or Parallel Notch Filter Designer / Calculator
Parallel Notch Fliter Designer / Calculator I have also used with success calculators from www.lautsprechershop.de >crossover calculations: >RLC calculators Strassacker: Speaker - kits - do it yourself You have to test the interaction with the simulation of your drivers frd/zma's with some software and the layout of an adequate (yours) crossover. |
#3 |
Hi Inductor,
Thanks for your quick reply . I will try out these circuits tonight and get building!Cheers, |
#4 |
Have had promising results with this calculator Strassacker: Speaker - kits - do it yourself
![]() Let me know if there'e anything glaringly wrong before I order parts please ![]() I take it I don't need FRD/ZMA software as I have already arrived at these values with an equaliser? Hence taking into results the natural response ![]() Thanks! |
#5 |
There will still be interactions you should give some consideration to. For example, if you have a capacitor crossing this driver which is causing it to begin rolling off at 3k5, then its effect will be reduced by this bandstop filter. Another example is that if your driver had a higher impedance in this region then this filter will be less effective.
For both cases the answer could simply be to increase the value of resistor you have calculated. On the other hand you could model it, your choice. No doubt you'll have some phase change so you may have some slight unexpected changes around the crossover region. |
| DCN23BOX Digital Crossover/EQ/Room Correction - Stock Clearance Sales | Robert GS | Vendor's Bazaar | 14 | 8th March 2012 07:26 AM |
| DEQX how to videos - speaker correction, digital crossover | Zodiac | Digital Line Level | 0 | 26th November 2011 09:10 PM |
| pioneer crossover cd-635 | ian33 | Car Audio | 9 | 3rd July 2011 05:46 PM |
| baffle diffraction correction and crossover network. | Aucosticraft | Multi-Way | 13 | 25th March 2011 12:18 PM |
| AKAI CD 93 or CD 73 cd players are sought | tuncay | Swap Meet | 1 | 11th December 2006 07:01 PM |
