full range driver opposing magnet in dipole configure
Old 16th April 2012, 04:30 AM   #1
sagamotto is offline sagamotto  Canada
Default full range driver opposing magnet in dipole configure
Hello DIY's friends...
Can someone here explain the effect(s) of say two 8" full range drivers put together in opposing magnet and wired in series of a dipole configure ?
how many drivers do i need to match my 100db bass onken ?
Its a 3 way design with the good old foster horn tweeter.
The 8" FR drivers I have on hand are those cheap and with the whizzer type.
Qts: 1.87, at 89 db.
Old 16th April 2012, 06:00 AM   #2
VaNarn is offline VaNarn  Australia
I assume you have something akin to an Altec 515 in your Onken enclosure with passive crossovers. I am afraid that your idea of two cheap 8" drivers no matter how you baffle them or even use horn loading, will not work.You could try something from the Pro Audio area from Parts Express or other suppliers.
Old 16th April 2012, 07:08 AM   #3
Well actually, the reason i asked the question to see if someone can tell me the effect of opposing magnet configuration on a high Q full range driver. This configuration is to be use for the mid range region of my 3 way design and by the way i forgot to mention that my bass driver is a 15" vintage Yamaha Ja-3881.
I only need to obtain a mid range near about 93-95 db to blend in between the the horn tweeter which i can further tune to match. As far as the low goes, you can't alway hear 100 db at all time. I mean bass only sounded when music signal allow in music. So, I don't see why the cheapo 8" full range can not work for my application...
Have anyone here already tried or currently experimenting dipole opposing magnet method?
Old 16th April 2012, 07:47 AM   #4
The crossover frequencies in a passive network are important in as much as how power distribution and directivity are to be dealt with,that is,unless you are using a plate amplifier with the Yamaha 15'' so that it is in effect a sub-woofer.The only issue with back to back spacing is what it is going to do to the sound image and details of the actual dipole and distances from walls is not known.Perhaps the Audax PR 170 is a better solution for you to contemplate.
Old 16th April 2012, 08:09 AM   #5
VaNarn... Thks for the quick replies...
BTW, its all passive 3 way design. The mid range I am planing to achieve is simply a dipole's series wiring. Infact its not even going to be in any enclosure either... Just two baffle pressing two FR drivers together (opposing magnet). I have not design the size of baffle yet... until I have gather enough infos.
Old 16th April 2012, 08:27 AM   #6
Radugazon is offline Radugazon  France
Radugazon's Avatar
Dipole opposing magnet ? That's a new term for me, but I think that I have been experimenting this with little baffle and variable spacing...absolutely no interest. IIRC, the same drivers in a classical layout work much better in radiation pattern or efficiency.
BTW, if you reverse the polarity of one driver, you gonna have a linear quadrupole. No match with your bass.
Old 16th April 2012, 12:23 PM   #7
"but I think that I have been experimenting this with little baffle and variable spacing...absolutely no interest. IIRC, the same drivers in a classical layout work much better in radiation pattern or efficiency.
BTW, if you reverse the polarity of one driver, you gonna have a linear quadrupole. No match with your bass. "
Just a curiousity, but what drivers did you experiment with ? was it a FR high Q driver for mid range duty?
Old 16th April 2012, 01:28 PM   #8
Radugazon's Avatar
Was a PA 10", (TS parameters here), with phase plug and improved basket, done by the company that produces SB Acoustic .
Qts 0,37, Vas 38 liters, Fs 65 Hz, not a good OB woofer, but a mid range. With Le = 0,21 mH, not a FR too, but all these radiation pattern tricks never concern really the upper range.
Old 18th April 2012, 03:53 AM   #9
My initial idea was simple, and seem to be in progressing, by combining the two drivers together (back to back or magnet to magnet) increases louder response (higher db gain) but also dipole advantage. Perhap it has alot to do with the FR driver magnet and energy storage pretty sure the parameter of the driver itself also changes. The sound I am hearing is clear and fast, very natural voice including string instruments, and uncolored. Even at higher volume play back (about 3 wts) both front and back cone vibrate very little, as well as my bass onken. If all this is happening from opossing magnet can someone here explain for me WHY?
here is the origin 8" FR spec:
Specifications: *Power handling: 30 watts RMS/60 watts max *VCdia: 1" Le: 0.68 mH *Impedance: 8 ohms *Re: 5.6 ohms *Frequency response: 100-16,000 Hz *Fs: 107 Hz *SPL: 89 dB1W/1m *Vas: 0.32 cu. ft. *Qms: 5.49 *Qes: 2.42 *Qts: 1.68 *Xmax: 2 mm.
Old 18th April 2012, 06:29 AM   #10
Charcoal is offline Charcoal  Ukraine
I tried such push-pull dipole with identic FR drivers. Soundstage was much more precise than with normal dipole, when bothe sides of one driver are sounding.
In push pull dipole with two divers - they vere placed in the same minimal sealed volume, so only front sides were sounding to the room in dipole (not bipole) mode. We called it here "simmetrical dipole"
full range driver opposing magnet in dipole configureHide this!Advertise here!
Best full range driver? markusA Full Range 106 3rd May 2013 02:06 AM
Peerless 830987 3" full range in dipole matevana Full Range 12 24th June 2010 10:39 PM
No-Name full range Driver ArjenShenzhen Full Range 13 18th August 2008 12:19 PM
Full Range Dipole Designs - Any Advice? Forster Full Range 5 9th January 2007 01:13 PM
full range dipole options in north america smak Full Range 15 22nd November 2004 11:48 PM
Copyright ©1999-2017 diyAudio
