All speaker gurus (including FR guys) need advice. - diyAudio
Old 15th April 2012, 05:31 PM   #1
aptquark's Avatar
Default All speaker gurus (including FR guys) need advice.
Hello all,
I have a pair of Sansui book shelf speakers from 1991 approx. and was wondering if I could replace the speakers with some of much better quality. The woofy is 6.5 diameter and the tweeter is a horn type. The cabs are sealed. The wood is 3/4 MDF and the dimensions are 8.5 x 9.5 x 14.5 inches (19.1872036 liters minus the 3.4 inch MDF...whatever that is). Any ideas or recommendations on what I could replace these with?
Thanks in advance for your time.
Spiro
Old 15th April 2012, 05:56 PM   #2
diyAudio Member RIP
This should suit, built sealed :
Parts Express DIY Project
Though you may need to used the truncated version of the tweeter :
Dayton Audio DC28FT-8 1-1/8" Silk Dome Truncated Tweeter 275-076
rgds, sreten.
Old 15th April 2012, 05:59 PM   #3
aptquark's Avatar
Sreten...you think the vol. will work? Also, I dont mind cutting the cabs if needed. There was also a lot of insulation in the cabs...should I put that back in if I go with your suggestion?
Thanks for the quick reply!
Old 15th April 2012, 06:01 PM   #4
aptquark's Avatar
Also, the article suggest a ported design...not sealed? I dont mind adding the port...you think it would be better than sealed?
19.1872036 liters = 0.6775897 cu. feet...minus the 3/4 MDF should yield the approx recommended size in the article?
Old 15th April 2012, 06:09 PM   #5
diyAudio Member RIP
Zaph|Audio - Bargain Aluminum MTM
Indicates porting is probably barking up the wrong tree at that box volume.
rgds, sreten.
I calculated your cabinets at 0.42 cuft, which indicated sealed to me for that driver.
I'd rather go sealed and well stuffed than a marginal vented alignment, which
it is at 12L. IMO you'd want 20L+ for a good sounding vented alignment.
Old 15th April 2012, 06:14 PM   #6
aptquark's Avatar
MTM huh? I cant do that with this cab though. So basically, if I used only one woofer..the sensitivity would be lower than 2 correct?
Old 15th April 2012, 06:23 PM   #7
20L sealed is pretty decent.
What are your thoughts on constructing your own overtop (so that you can bevel or round over the corners) and getting some Mass Loaded Vinyl and acoustic fill on the inside of the cabinet?
Here is a rather high-end design with sufficiently close design dimensions (9"w x 16"h x 10"d and 15L)
As long as you mass load the walls a bit (and add some bracing) you should come very close to that 15L. Then you just add the vent and voila:
Mandolin Speaker Kit / Pr
Of course, constructing the box from scratch would get the best possible results
But still, this will give you fantastic performance from 40hz to 20khz.
Old 15th April 2012, 06:28 PM   #8
aptquark's Avatar
Great drivers...but want to keep it cheaper and also try to not build other cabs.
I will be building some floor standers later, so I was trying to do a cheap quick and dirty on this build.
Old 15th April 2012, 10:02 PM   #9
diyAudio Member RIP
They are not 20L, they are around 12L and of course a 4
ohm MTM would be a lot more efficient, nature of the beast.
The Karma Indignia is a design by committee, with what that
entails. Sealed vs. ported was inevitably resolved by making
it ported and saying you can always block the ports, but I
personally wouldn't bother cutting out and fitting ports.
Well stuffed sealed will be better than half-baked ported.
If you do go for the KI's it will be fairly cheap, fairly quick,
and not particularly dirty, and presumably miles better
than the current drivers and x/o, but expect a drop in
efficiency, to go with far better bass extension.
Not the last word in quality, more like the first real step.
rgds, sreten.
Depending on placement they'd probably benefit from
a little bass bass boost from a typical tone control.
Old 15th April 2012, 10:58 PM   #10
some Sansui drivers of that era weren't too bad, typically mid-q drivers in a box a bit too small....
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Need Advice from Amp Gurus Juke425 Class D 5 28th July 2008 03:20 AM
Need advice from the analog gurus davidlzimmer Analogue Source 21 23rd July 2007 11:23 AM
Need the gurus advice on sub undertoe Multi-Way 18 16th December 2003 12:05 AM
Copyright 1999-2017 diyAudio
