Nuts and bolts for binding posts - diyAudio
Old 3rd October 2003, 02:25 PM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Nuts and bolts for binding posts
Just skimmed through an awesome thread on DIY binding posts, but I don't have the energy to make something that complicated for this project.
Since it's cheap to get hold of galvanised steel nuts and bolts, I was thinking along the lines of using a large diameter bolt and three nuts per post, with a hole cut through the bolt to insert bare wire into.
Any problems?. In particular, is galvanised steel ok for this job, or is there significant drawbacks over copper or those normal binding posts?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 3rd October 2003, 02:40 PM   #2
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
I dont know that zinc, or galvanized steel, would be all that ideal for audio.
It shouldn’t be too difficult to at least find brass hardware from hardware, plumbing, or boat supply stores.
You didn’t like the welding connectors?
Old 3rd October 2003, 02:48 PM   #3
HDTVman is offline HDTVman  United States
I agree. At least go for brass. You can get into dissimilar metals problems with zinc/copper interface. Brass will still have the problem but to a MUCH lessor degree.
Later
BZ
What ever makes the tunes flow
Old 3rd October 2003, 02:55 PM   #4
roddyama's Avatar
Galvanized steel would be a poor choice for a conductor. It's magnetic, the resistance is at least an order of magnitude higher then copper. I'd go with brass or better yet threaded copper rod.
Rodd Yamashita
Old 3rd October 2003, 03:22 PM   #5
Da5id4Vz's Avatar
Cam-Lok welding conectors by Crouse-Hinds:
Old 3rd October 2003, 04:09 PM   #6
Can I put in a plug (ha ha) for Speakon connectors here?
They're airtight and they don't rattle, they allow biwiring as standard, they have very generous current ratings, they have proper materials for the contacts and they allow very easy swapping between amps, cables and speakers when you're A/B testing.
I wouldn't use steel, particularly if you're joining it to copper and passing a current through it. One side or other's going to corrode horrendously.
Cheers
IH
Old 4th October 2003, 03:23 AM   #7
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
Speakon = TEH AWESOME
Speakon = TEH EXPENSIVE
Old 4th October 2003, 03:50 AM   #8
haldor is offline haldor  United States
The're not bad. About $5 to $8 US each in small quantities.
They also lock into place and will take to a #12 wire. I use them on all my PRO aspeaker level connections. Much better than a 1/4" phono jack. You've got to wonder what idiot came up with the idea of using a connector that shorts the amp every time you plug or unplug the speaker.
Phil
Old 4th October 2003, 05:13 PM   #9
Nappylady's Avatar
You hit the nail on the head with the 1/4" connectors... I will NEVER use them on any of my speakers!
I've been using, thus far, Radio Shack binding posts with singular Cat5 cables. My dad and I have some plans to build and use small vices of copper, to secure speaker cables. When we'll actually get around to building them is another story...
(hijack) Anyone know where to get stranded Cat5 instead of solid? I'm always afraid I'm going to break the solid stuff.... (/hijack)
Old 4th October 2003, 05:19 PM   #10
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
But the solid stuff is the good stuff! That's why people use CAT 5
for audio!
BAck on topic: : hardware stores have some copper bolts in the electrical section by circuit breakers. These are for use to connect to the grounding of the house system. Also some cool copper clamps, but too big for amp cable use.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
binding posts h_a Parts 21 12th January 2009 11:10 PM
Binding Posts ANDYLASER Swap Meet 7 23rd November 2006 11:33 AM
Tiny Nuts and Bolts PHilgeman The Lounge 3 24th May 2004 04:55 PM
I'm going nuts over these bolts Hefty Multi-Way 8 24th December 2003 10:06 PM
Nuts and bolts, and ground and ...caps ftorres Digital Source 13 1st August 2002 04:28 PM
Copyright ©1999-2017 diyAudio
