Internal Wirng - Car Battery Power Cable
Old 4th October 2003, 01:18 AM   #11
andrew01 is offline andrew01  Australia
A better idea is to use copper "buzzbar" , it's a bit expensive
though. You'll need to cut some slots in the rear of your
enclosures to pass the buzzbar's through. Around 6" x 1/2"
approx. These have the advantage of zero / immeasurable resistance over a long length & high current capability.
Andrew
TFPIC
Old 4th October 2003, 01:40 AM   #12
MJK is offline MJK  United States
Two comments :
1. Vikash, when you measured the resistance of your CAT5 cable did you remember to subtract out the resistance of the meters leads. Hook the positive to the negative lead and measure the meter's resistance (mine is 0.4 ohms) and subtract this value from the reading when measuring the CAT5 wire. I have made a similar set of speaker cables that are about 8 ft long and got a resistance less than 0.1 ohms (below what my DMM meter could measure) so I probably should have used my LCR meter.
2. To reinforce GM's point. If you look at the voice coil wire, it is probably tiny compared to all of the other wires in the signal path from the amp to the driver. The voice coil probably has 100 ft of wire or maybe even more (enough to produce an 8 ohm DC resitance, I'll let somebody else calculate the length). So ask yourself this question. At what point does an 8 ft speaker cable, and all of the crossover wiring, become as big a factor as this long length of very small voice coil wire. I consider this analogous to water flowing in a fire hose through a 10 ft long nozzle the diameter of a drinking straw. How important is the diameter of the fire hose?
In reality the speaker cable and the interconnects are important and can make a difference in the sound. My experience has been that as long as the DC resistance is kept very small, the differences in cables occur at the high frequencies where the wire/connectors can roll off the response. At these frequencies the cable can become inductive or capacitive and alter the sound of the system. But at some point you reach the level of diminishing return, I think car battery cable may be way out there on the curve.
Try the CAT5 wire as shown in the pictures, I was surprised at how much better it was compared to my more expensive cables (now shoved under the couch). Simple, cheap, easy to make, how much more could you ask for in a cable?
Old 4th October 2003, 11:20 AM   #13
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Martin,
No I didn't subtract the DMM's resistance. After doing so, I re-measured the cable resistance = ~0.01 Ohms. Thanks for pointing that out.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 4th October 2003, 01:07 PM   #14
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
Default Solid vs. stranded conductor
Thorsten Loesch seems to make a coherent argument for the superiority of solid conductors over stranded in this article.
Internal Wirng - Car Battery Power CableHide this!Advertise here!
Which cable to use on Aleph internal wiring? Sony Pass Labs 4 25th May 2005 02:05 AM
What cable for internal wiring? roibm Everything Else 11 27th November 2004 11:18 AM
Shielded cable for internal amp wireing: where do I connect the shield? Bricolo Parts 11 26th June 2003 01:26 AM
Internal speaker cable for high power disco/pa cabs Bull Multi-Way 18 22nd June 2003 05:29 AM
