Old 13th April 2012, 12:28 AM   #11
Originally Posted by Puffin View Post
If you remove the rear panel from a speaker are you likely to experience what an open baffle might sound like?
No. You're going to loose your bass and get a multi-lobed polar mess at high frequencies where the timbre won't sound natural.
Old 13th April 2012, 05:43 AM   #12
Puffin is offline Puffin  United Kingdom
Ok
Old 13th April 2012, 12:10 PM   #13
Jim Shearer's Avatar
You may find it of interest to check out MJK's site:
Quarter Wavelength Loudspeaker Design
Martin has several papers on OB design and performance.
As many here already know, Martin also has MathCAD worksheets for modeling a wide variety of speakers.
Cheers, Jim
A day without music is like a day without food.
Old 13th April 2012, 01:11 PM   #14
It is possible with a large speaker in a large cabinet that taking the back
off will sound OK, but this presumes the box is a boom box in the first
place, fitted with a high Qts driver with a very prominent upper bass peak.
A well designed box and driver simply won't work with the back off, no bass.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 13th April 2012, 02:23 PM   #15
Sreten. The speakers in question are PA speakers that could be said to be a bit "boom boxy" 15" bass, mid-range horn and 5 bullet tweeters. The whole cabinet is un-damped and there is a large diameter, but fairly shot port on the rear. I have to say that they are not all that bad having used them in my main system
Openly Baffled Puffin Full Range 4 7th October 2009 02:49 PM
Magnetar. Openly Baffled ? Graham Maynard Multi-Way 11 16th July 2008 02:48 PM
Openly Baffled: DDR in Extremis Z33 Multi-Way 129 24th May 2007 05:52 PM
openly baffled!!! noobish help wanted psychosteve Multi-Way 8 20th March 2005 03:56 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
