Hey guys, new here.
For my college project I want to build and design a set of small speakers. I want these to be of reasonable quality as I am going to use these myself afterwards. My first thoughts was a two way system, however I have no idea how to wire crossovers or what drivers/tweeters to use together. Someone has mentioned to me that a full range speakers are much more simple to wire but cabinets are more complex, so would a pair of these be more suitable? My college course is General Art and Design, so if anyone can give me inspiration on funky, yet good enclosure designs, that would be fantastic. Sorry if this is posted in the wrong place. Many thanks. |
#2 |
Dilletante, tinkerer and beggathoner supreme
Hmmm "Funky" See Andy Graddons website for funky
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
Soakin' up the Sound!
The Parts Express TechTalk forum is about 99% DIY speaker oriented. If you look around the site, you'll probably find something you like. And I'm sure you can get as much help as you need. A lot of people like the funky side of speaker building too.
http://techtalk.parts-express.com/ Mike
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals Jolida SJ502B, Mark Audio Alpair 10.2s
#5 |
I have just read that Single driver speakers are only really suitable for moderate sound levels and music such as voices and jazz? How true is this information?
Thanks |
#7 |
Audio Engineer
For £40 you are not going to get the best drivers in the world. It is a very simple first order electrical crossover, which means the frequency response is probably going to be poorly controlled.
However the statement in the add is probably true it will sound allot better than a pair of speakers you could buy for £40. You are not going to get massive volumes from speakers of this type. If you want to achieve student party levels the easiest way is to buy larger drive units as they are usually more efficient. However if you have a smallish room the will probably be enough. At least it simplifies your problem to building a funky cabinet for them. If you told us more of what you want to get out of the speakers then we could tell you more about what drivers and solution you need. For instance how power full is your amplifier. If it is a tube amplifier then you will need a very sensitive speaker. If it is a 1000W PA amplifier then something based on PA drivers would have more chance of surviving. Do you want to use it for parties. What sort of music do you like and how loud do you normally listen. Regards, Andy |
#8 | |
Its cheap and cheerful and very good value for £40 delivered. The bass driver specs : Resonance: 50Hz Sensitivity: 89db 1w@1M Impedance: 6 ohms Power: 60 watts nominal Frequency range: 46-6000 hz Qms: 1.48 Qes: 0.57 Qts: 0.41 Vas: 29.5 litres Chassis: 180mm square Baffle cutout hole: 140mm Its designed to work in a ~ 10L sealed box, ~ 15L vented box. The simple x/o almost certainly has no built in BSC and the driver Qts is low enough that it would work well in decent sized BIB's and BVR's designed for FR drivers to boost the low adding some BSC. The tweeter may need some padding to bring it level with the bass/mid, it really is a cheap x/o, but the drivers alone are easily worth £40. FWIW the kit should work well in the FreddieChang BVR posted earlier. Fill the triangulated section with sand for stability and damping. Add some bracing. Top needs foam lining. Possibly invert the drivers, i.e. bass/mid top, tweeter just below. possibly offset tweeter centre to 0.6 of baffle width and build mirrored pairs. Bass can be adjusted by adding pillow stuffing behind the driver. They will go lot louder than a FR, and for the price hard to better. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#9 |
Andy seems to have shut own completely
Argos Loudpeakers seems to be no more.
#10 |
maybe u should build something like the Cyburg needles or Frugal Horn MK3
Cyburgs-Needle for Tangband W3-871S Frugel-Horn Mk3 |
| Help with small Subwoofer project | Allan74 | Subwoofers | 22 | 6th October 2010 09:43 PM |
| Small first project | BERENO | Multi-Way | 7 | 4th August 2008 08:16 PM |
| Small computer sub project | Dr.EM | Subwoofers | 1 | 6th December 2007 03:20 AM |
| Small 2-way Project | John_Patr1ck | Multi-Way | 13 | 17th July 2006 11:09 AM |
