Old 17th April 2012, 08:13 PM   #51
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I got a spool of this stuff to start wiring up my new room, I couldn't be happier with it. 250ft for $75 is hard to beat.
12 AWG OFC Speaker Wire 250 ft. 109-065
You probably don't need that much though.
Oh, UK, scratch that, shipping would probably be ridiculous.
Old 17th April 2012, 09:30 PM   #52
The cheapest stuff Richer Sounds does will be fine :
Speaker Cables | Speaker Accessories | Richer Sounds
Available per metre. Tinning both ends with solder is a good idea.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th April 2012, 09:44 PM   #53
MrNick is offline MrNick  United Kingdom
"Tinning both ends", is that just literally applying a little solder to either ends of the cable?
Old 17th April 2012, 10:00 PM   #54
DrDyna's Avatar
Yep.
Old 17th April 2012, 10:25 PM   #55
Hi, Usually quite a bit of solder, tin all the exposed copper, rgds, sreten.
It prevents whisker shorts and prevents almost completely corrosion issues.
When you strip the ends and twist them for soldering try not to get finger
grease on them, use a tissue, solder them immediately, and discard say
the first 1cm of any cable that is not freshly cut, the end has oxidised.
You'll also find tinning wires and tags greatly eases quality drive unit soldering.
Old 18th April 2012, 11:00 AM   #56
Can I just use any old solder flux then?
What do you mean by "tags"?
Old 18th April 2012, 12:35 PM   #57
DrDyna's Avatar
Tags are the terminals on drivers and input cups or the terminals on "tag strips" people often use building crossovers. It's basically any small piece of metal that's designed to have a wire soldered to it.
As for flux, electronics solder will almost certainly be rosin core, meaning you shouldn't have to add any additional flux at all.
Old 19th April 2012, 08:50 PM   #58
Would these two products be suitable for finishing the cabinets in?
Colron Wood Dye
followed by
Colron Interior Lacquer
Old 19th April 2012, 09:36 PM   #59
mondogenerator's Avatar
I cant beat £40, but i just got 2 mission cp-134 for 17Eu each, and cp-168 for 19 Euro each, and 4 of the Visaton FRS5X for ~9 Euro each. Two sets of cheapish 2 ways for £107, so ~$54 minus crossover though
Also can vouch for that speaker cable, ive got a small amount here, and about 10ft of the old 79 strand version Maplin did years ago lol
It still amazes me every time I get something right
Old 19th April 2012, 10:23 PM   #60
Colron Wood Dye
followed by
What are you making the cabinets out of ? FWIW for a cheap
build I'd simply apply a wax finish. Cheap, simple and painless.
Tougher polyurethane.
rgds, sreten.
Help with small Subwoofer project Allan74 Subwoofers 22 6th October 2010 09:43 PM
Small first project BERENO Multi-Way 7 4th August 2008 08:16 PM
Small computer sub project Dr.EM Subwoofers 1 6th December 2007 03:20 AM
Small 2-way Project John_Patr1ck Multi-Way 13 17th July 2006 11:09 AM
Copyright ©1999-2013 diyAudio
