Tweeter - How much series resistance do I need?
Old 25th April 2012, 05:30 AM   #21
Jim W is offline Jim W  United States
You mention that the mic position is the same relative to the speaker, but I would take it a step further and measure both speakers in exactly the same place, keeping everything as similar as possible, including the position of you in the room.
Edit: looks like it's a bit late for this suggestion...
Old 25th April 2012, 03:16 PM   #22
Ron AKA is offline Ron AKA  Canada
Actually it is not too late. I think I did exactly as you suggest. I used the same right channel of the amp for both speakers, without touching the volume control or anything else on the preamp. They are floor standing so I put masking tape on the floor and marked the exact position, and then just interchanged the speakers. The stand for the mic or the mic was not touched between the test of the left and right. For the last test I even put some throw rugs on the floor as it is hardwood, but it did not seem to make a difference. To read the iPod Touch I used a stool about 4 feet behind the mic and stood on that to read the dB level without getting close to the mic. That in fact seemed to be the biggest influence. Totally different readings if you stood right behind the mic. Even from 4 feet back leaning forward and back would change the dB level with some of the frequencies. Others it was rock solid no matter what you did. Those rock solid responses were the ones I depended on the most, and in most cases those were 85 dB. I suspect 85 dB is very close to the true sensitivity at whatever voltage I was using (did not measure it).
In any case it is not hard to see why an anechoic chamber is used with a remote mic to measure frequency response accurately. It is not an easy thing to do accurately. Even turning everything off I could in the house I did not get background noise below about 33 dB. I think if I could have found pink noise bands instead of pure notes it would have been less sensitive. I do have those on vinyl but that is too much of a pain to use...
Old 26th April 2013, 06:53 PM   #23
Tomos is offline Tomos  Croatia
Guys, Im new here and I have some strange idea but need someones opinion. Its about tweeter in my two way system. I have xo for 4 ohm tweet but now Im putting in a 8 ohm driver. Beside that, this tweeter is about 5db louder than midbas. The idea is to put 8 ohm 20 w resistor in paralel to driver after xo and fix my problems. Or not?
Old 28th April 2013, 02:48 AM   #24
strawberry is offline strawberry  United States
strawberry's Avatar
Tomos, sure, if you make the other resistor 2.5 ohm.
Old 28th April 2013, 06:53 AM   #25
Thanks for responce. However, other resistor combination would alter impendance/resistance, so i dont think this would be the option, xo wise.
Old 28th April 2013, 08:38 PM   #26
strawberry's Avatar
Tomos, was the 4 ohm tweeter un-attenuated, no resistors?
Old 28th April 2013, 08:54 PM   #27
True. Pure 12db xo at 2.5kHz for 4 ohm tweeter. I think that splitting drive current in half would atenuate sound pretty much, maybe even for 5 db. But i question sound quality in this case. I've never done this before but I don't have much time for testing, that's why I ask for other opinions. I know my own test would be the best option.
Old 28th April 2013, 09:31 PM   #28
strawberry's Avatar
4 ohm tweeters are often very loud. That it is not attenuated sounds strange. Perhaps your speakers were too bright in the past? I think you should try my recommendation. 2.5 ohm in series with the capacitor and 8 ohm across the inductor. Most crossovers are so screwed up from the factory anyway. There is nothing there to "guard". If the tweeter becomes too attenuated from this, move the 2.5 ohm to the side of the inductor, with the other resistor. Make the 2.5 ohm 20 watt. For example two 5 ohm resistors in parallel that are 10 watt each.
Old 29th April 2013, 01:55 AM   #29
Ok, I'll consider that. Why do you think it would't run in my firtst idea?
What about sound quality since such significant signal splitting?
Old 29th April 2013, 03:10 AM   #30
PeteMcK is offline PeteMcK
Tomos, use the L Pad calculator I linked in post#6 to work out your resistor values, for a Ztotal of 4 ohms
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Tweeter - How much series resistance do I need?Hide this!Advertise here!
The down side to adding series resistance to horn drivers AllenB Multi-Way 34 25th July 2017 07:21 AM
L-Pad variable resistance dial in tweeter volume kach22i Multi-Way 9 4th January 2012 03:42 PM
Info on Resistors / series resistance one1speed Full Range 7 24th February 2006 02:29 PM
Measureing Cable & Crossover Series Resistance Allan Multi-Way 12 3rd January 2005 12:01 PM
Add Series Resistance of the Wire in TS measurement? r_s_dhar Multi-Way 1 27th July 2002 12:06 PM
Copyright ©1999-2017 diyAudio
