Beyma 8cx300nd - diyAudio
Old 2nd April 2012, 08:51 PM   #1
Default Beyma 8cx300nd
Hey guys,
I could get two Beyma 8cx300nd Coax drivers quite cheap.
Since I was always intrigued by the looks of those drivers and the idea of a coax speakers, I'm really thinking about buying those.
Sadly you can't hardly find anything about those drivers - no reviews, no building plans, nothing.
Anyone of you got experience with them?
I primarly would use them for homecinema and listening to Rock/Electro, they would be supported by two Tangband W8Q-1071F.
regards,
Mike
Old 2nd April 2012, 10:19 PM   #2
KSTR is offline KSTR  Germany
KSTR's Avatar
You might contact member Charles (screen name "phase_accurate"), he's about finishing a design with them.
Other than that, it's a beyma, what else need to be said... this is excellent pro stuff (I'm biased, though). Passive XO will need some expertise and knowledge.
Old 3rd April 2012, 08:54 AM   #3
Really great drivers!!! I heard them, and you will be very happy with them, when you get the crossover right.
Old 3rd April 2012, 09:06 AM   #4
Well...
The XO was my biggest concern, since I don't have that much experience in XO design... .D
Old 3rd April 2012, 01:33 PM   #5
I think you could make quite a lot of noise with this combination. Do you already have these TB woofers ? Do you want to go active ?
Charles
Old 3rd April 2012, 02:28 PM   #6
Yeah, the TBs are already lying around - I alwas planned to integrate them into a big, modular sideboard.
At the moment I'm running a stereo setup with 2 active 15" Subs (each with his own poweramp) together with 2 larger bookshelfspeakers (the subs serve as speakerstands).
I used to run the system on a valve preamp + an old Marantz poweramp.
Recently I acquired a Marantz SR8002 - so the pre and poweramp will be replaced (the receiver is better sounding in my ears).
Active would be an option (together with a Behringer CX2310 or DCX2496 ) BUT I have no idea how I would realize this with an A/V receiver.
The room itself is more LEDEish furnished.
Old 3rd April 2012, 04:46 PM   #7
chrismercurio's Avatar
I have been curious about these too. Not much written about them anywhere. They are used in the Dynamikks DB8.2.
Old 3rd April 2012, 07:40 PM   #8
Some stuff I found:
Paramètres haut-parleur de THIELE et SMALL, sans filtre ni ampli
Old 4th April 2012, 05:53 AM   #9
That is quite a nice data-sheet. But the proposals for fourth- and sixth- order bandpass boxes are a little awkward !
Charles
Old 4th April 2012, 09:15 AM   #10
So anyway, any ideas for a passive XO?
Mike
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 03:58 PM
beyma parak21 Subwoofers 5 8th February 2012 06:47 PM
MLTL for Beyma 8CX300Nd ? Stiffler Full Range 7 6th September 2011 06:20 PM
Beyma SB18 muri Subwoofers 4 12th May 2009 09:41 AM
Has anyone experience with Beyma??? DarkOne Multi-Way 1 25th February 2002 12:29 PM
Copyright ©1999-2017 diyAudio
