old Tline program-valid? old Tline program-valid? - diyAudio
Old 1st October 2003, 04:04 AM   #1
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
Default old Tline program-valid?
is this program any use at all thesedays?
i was looking that the 'magic' deathboxes over at car audio forums,and magic'snailshells' that hit 140db with 6.5" speakers,and i saw this loading on the cone in this program with a little compliance behind the speaker ....could be different things,,no one seems to know enough to say any facts..
a larger compliance shifts the frequency of 'booming ' in this case (high Q speaker) downwards.
PROGRAM DESCRIPTION
TLBOXMOD is a computer model of a transmission-line
loudspeaker system that uses the acoustic model proposed by
Bradbury (The Use of Fibrous Materials in Loudspeaker
Enclosures, JAES, vol. 24, pp. 162-170, 1976). In addition
it has provisions for tapering the line, inserting a coupling
volume between the driver and line, and for a line
cross-section different than the driver piston area. Also,
the air speed in the line is selectable as is the porosity of
the line filling.
Old 1st October 2003, 04:09 AM   #2
mikee12345's Avatar
compare with same speaker in ported box 55l
the Tline shows much higher loading at a very specific point
Old 1st October 2003, 10:58 AM   #3
MJK is offline MJK  United States
In my opinion, the TLBOXMOD program does not work. It is based on the moving fiber theory proposed by radbury which was in favor at the time. This theory assumed dramatic reductions in the speed of sound at low frequencies as the fibers coupled with the air and effectively increased the moving mass. I tried using this theory for years and was never able to correlate it against test data, it was always way off at low frequencies.
Bullock wrote an AES paper where he tried to correlate his program against test data. If I remember correctly, he concluded that the correlation was poor.
Old 1st October 2003, 01:03 PM   #4
mikee12345's Avatar
Thanks for shedding some light on this
i thought it maybe some retro not understood or well implemented idea.
cheers!
old Tline program-valid?Hide this!Advertise here!
No thread specified. If you followed a valid link, please notify the webmaster MJL21193 Everything Else 2 10th October 2008 04:14 AM
How To Get The OB Sound From A TLine Or Sealed Box?? Ben Reginato Multi-Way 17 10th May 2008 01:29 AM
Stillpoint ERS EMI/RFI Suppression Cloth - snake oil or valid upgrade? adhoc Parts 19 16th December 2006 05:35 PM
Which amp for Jordan JX92S Tline ? founzie Tubes / Valves 24 13th November 2005 08:44 AM
Valid Kid-Proofing Strategy? jjasniew Digital Source 2 30th December 2003 09:10 PM
Copyright ©1999-2017 diyAudio
