Old 22nd March 2012, 08:41 PM   #1
percy is offline percy  United States
Default Single channel measurements for xover design ?
Please educate me –
Single channel measurements do not have a “reference” signal looped back from the output. An example of this would be using a mono mic input.
Question is –Are such single channel measurements still suitable for crossover design ? Please explain your answer - Why ?
You can assume the output/input amplifiers and mic all have flat amplitude response, or atleast have been compensated for in some way (calibration files).
Old 22nd March 2012, 09:46 PM   #2
speaker dave's Avatar
The reason for dual channel measurements is that you can subtract the input from the output and not worry about what your stimulus was. If it wasn't flat the error will cancel out. In reality if you stimulus is flat then single channel is fine, the measurement accurately reflects the transfer function. Finally, even of your stimulus isn't flat, you can measure it with a single channel type, save the measurement and subtract/divide it out later, to cancel the errors.
David S.
Old 23rd March 2012, 01:00 AM   #3
any implications in terms of phase ? that's what I was trying to allude to by saying 'for crossover design'.
Old 23rd March 2012, 02:11 AM   #4
No, a single channel system is just as good at measuring phase.
HELP for change parallel design to Series design Xover FREEMANMKII Multi-Way 11 21st September 2010 07:31 AM
Parasound HCA-1206 6-channel amp and Behringer CX-3400 active xover wigginjs Swap Meet 6 16th October 2008 01:43 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
My 2 way design... need xover help AudioGeek Multi-Way 4 2nd April 2007 01:28 PM
Xover design help Kram Multi-Way 38 5th January 2003 08:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
