Old 21st March 2012, 10:54 AM   #1
Default Speakon Connector wiring, 4 pole mono amp
I am trying to find info on if it is possible to wire the connectors in parallel, eg split one wire to +1 & +2 and the other connected to -1 & -2 and do this on both ends of the cable? I want to run the amp in stereo mode, not bridged and I am not sure if this will affect the way the amp outputs power?
Why I want to do this is b/c I am running about 60ft cable runs and I went with 10 awg speaker wire and speakon connectors can only handle 11 awg.
Cheers
Old 21st March 2012, 11:33 AM   #2
b1o2r3i4s5's Avatar
So basically, you're fitting a 2-Core speaker cable in the speakon connector and each core is 10awg correct? and you want to connect one side to a power amp and the other side to one speaker or a speakers in parallel?
Unless i am mistaken, I don't see how this setup can run in stereo mode.
Old 21st March 2012, 11:55 AM   #3
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
its not very clear what you want to do, what type of amp it is, or how the amp is normally wired.
Old 21st March 2012, 12:18 PM   #4
Yes
I am not sure if I am explaining this right so I posted a pic of what I want to do.
Edit this is the amp , Yamaha P7000s
Old 21st March 2012, 12:44 PM   #5
b1o2r3i4s5's Avatar
From the Amp's user manual You can see that Output A's +1 and +2 terminals are connected to Amp A and Amp B's outputs respectively, by shorting +1 and +2 the two amp's outputs are shorted together, this will cause the amp to overload when a large signal is outputted so the answer to your question is NO, THIS WILL MOST LIKELY DAMAGE YOUR AMPLIFIER.
However, the terminals A1- and A2- are both connected to the ground so it is okay, It is also okay to do this for Output B's speakon connector since B2+ and B2- is not connected to anything. Hope this helps.
File Type: jpg Screen Shot 2012-03-21 at 8.36.11 PM.jpg (72.5 KB, 78 views)
Old 22nd March 2012, 03:55 AM   #6
Pallas is offline Pallas  Pakistan
Wire the speaker end however you want. As long as you're consistent between cable and speaker, it doesn't matter.
However, at the amp end just trim the 10AWG wire to fit within the correct screw hole. (I would do that at both ends.)
If you do the ends differently, be sure to label the wires appropriately!
Old 22nd March 2012, 04:13 AM   #7
Ok, so from the manual, for speaker "A" on the amp side I need to connect the positive to +1 and negative to -1. For speaker "B", I need to connect the positive to +1 and negative to -1?
Is this correct?
BTW, I tried wiring the 10 awg wire to the connector and with a fair bit of coaxing I got it to fit OK.
Old 22nd March 2012, 04:46 AM   #8
b1o2r3i4s5's Avatar
So you are only using connector A now?
If so then yes, but take note that most speakers only use channel 1 in the speakon connector.
Otherwise, you're probably using using 2 Speakon cables from the amp to 2 speakers (1 cable each) you just need to wire channel 1 (+1/-1) for each cable. Connect Amp output A to speaker A and output B to speaker B.
Old 22nd March 2012, 04:59 AM   #9
No,no,no. Two connectors and two sets of +/- cables. That is what I was trying to put across in my last post.(The English language is failing me.) Speaker 1 to terminal "A" ,+1/-1 and speaker 2 to terminal "B", +1/-1.
That should make it stereo if I am not mistaken? Thats what I want.
Thanks for help BTW.
Old 22nd March 2012, 05:04 AM   #10
b1o2r3i4s5's Avatar
[S] Sorry for the double post but [/S] heres the Pic of what i mean in case you're confused.
Yes, exactly that.
EDIT: seems that BBcodes don't work here... [S][/S] = strike-through text
Wiring a DPDT for direct in & 2-100k mono pots ..? JandG Tubes / Valves 2 5th December 2009 03:51 AM
speakon in DIY amp? dvenardos Class D 31 2nd November 2009 04:48 PM
ML-Voigt Mono-pole for Fostex FE126 nafunga Full Range 0 5th August 2008 06:10 PM
Stereo/Mono 4x12" Marshall cabinet wiring tone1963 Instruments and Amps 5 5th January 2008 09:17 AM
Internal wiring, connector question tempoct Class D 0 20th January 2006 08:50 PM
Copyright ©1999-2013 diyAudio
