Old 21st March 2012, 05:46 AM   #1
AllenB is offline AllenB  Australia
Default Using baffles to contain room reflections
I am trying to find a device that will prevent a ceiling reflection. My main constraints are its height, and that it's broadband.
I have GD and comb filtering issues extending down into the bass. I need to manage 250Hz as much as possible, and preferrably everything above.
I have thought of hanging baffle curtains to reflect the sound back to the front wall where I have enough absorption to handle it, rather than using an 8" high absorber, or a narrowband panel absorber.
Can this be reliably done with low profile curtains? As an example in the diagram, where a single baffle 'A' could be used to deflect this span of reflections, so could the 'B' or 'C' options but would they restrict the lower working frequency?
Old 21st March 2012, 10:35 AM   #2
StigErik's Avatar
Curtains are acoustically transparent at 250 Hz, so this will not work. But if you build it with solid boards, it will become a kind of diffusor, though not very efficient. The sound will not reflect back, but rather be scattered around. Its better to build a deep and large absorber, or a proper QRD diffusor.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 21st March 2012, 10:52 AM   #3
speaker dave's Avatar
Heavy curtains or 2" fiberglass would do a good job at 250Hz.
Coefficient Chart
Here is a chart of absorption coefficients. I think you might also pick up a little advantage from the material being off the surface, so you might experiment with 1".
A multiplicity of shorter curtains should also work, as long as, from your listening point you see no bare ceiling around the reflection point. If the curtains are longer than the minimum then the bounce wave will be passing through multiple layers, increasing efficiency.
David S
Old 21st March 2012, 01:00 PM   #4
StigErik's Avatar
The point was to reflect the waves back, not to absorb them ... ? In that case, neither curtains or fiberglass will do the job. Only solid materials will work, but as a whole the original idea here is flawed in my opinion.
Its better to absorb or diffuse in the ceiling rather than trying to reflect back to the front wall.
Room acoustics question... reflections ! Mooly Multi-Way 24 24th February 2011 06:49 AM
Early diffractions / reflections and EQ HiFiNutNut Multi-Way 27 30th April 2009 09:17 PM
Realism and room reflections 454Casull Multi-Way 4 26th November 2007 06:20 PM
Some reflections on politeness vs. briefness Christer Everything Else 6 24th June 2003 04:36 AM
LM3875 Poweramp- reflections on components... halojoy Parts 101 15th February 2003 12:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
