Old 21st March 2012, 05:04 AM   #1
1fspd is offline 1fspd  United States
Default Sand filled 2 way
I'm building a sealed two way and before I put blade to wood, I thought I'd ask for opinions/thoughts on the sand filled cabinet walls vs a stack lamination construction.
The sand filled speaker has interior/exterior side and back walls of 3/4" MDF. Font baffle, top and bottom are a 1.5" MDF/dampening/MDF layer sandwich. Exact dampening material remains undecided.
I've never used sand in a cabinet before, but in theory seems great. Stack lamination/translam type enclosures also seem interesting.
Wanted to try something a little different.
Thoughts?
Old 21st March 2012, 05:21 AM   #2
frugal-phile(tm)
planet10's Avatar
I'm not a big fan of translam... makes pretty shapes but has lots of drawbacks
The sand filled willbe monstrosuly heavy, but has been shown to be VERY effective dating all the way back to Briggs.
As well either construction will be better (i think substantially) if you use good plywood instead of MDF.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st March 2012, 07:31 AM   #3
Lusk is offline Lusk  Australia
Lusk's Avatar
How about doing both? I did a base enclosure with stacked layer and lead shot that worked very well, need a trolley to move it though.
Old 21st March 2012, 09:54 AM   #4
What drawbacks? Interested.
Regards.
Michael
Old 21st March 2012, 01:34 PM   #5
Lusk - cool idea. I considered something similar... a column (top-bottom) of sand just to either side of the driver in the attached stack lam model. Thought it would be a way of separating driver vibration from the rest of the cabinet, without adding significant weight.
Planet10 - I also like the look of stack lamination speakers, but am inclined to think the sand filled cabinet would perform better...but i've never built either so appreciate your input - thanks
I've heard of cracking issues with stack lamination designs - A solution to MDF expansion on joints, translams etc.
Old 21st March 2012, 04:26 PM   #6
2 1/4" layers of plywood separated by cement board for sides and back w/ a double layer of plywood on the baffle will do as well as sand and be lighter (not light, but lighter).
Use one of the construction panel adhesives to glue the cement board to the plywood and you've got contrained layer construction. Should handle panel resonance just fine.
I was so much older then, I'm younger than that now.
Welded steel frame sand filled enclosure JoeM Multi-Way 29 9th July 2009 12:57 PM
oil filled capacitor jaudio Parts 5 11th November 2006 10:36 PM
My sand filled curved side walls project in progress! sqlkev Multi-Way 17 11th August 2006 05:27 AM
Oil Filled Capacitor not upright OK? pengboon Tubes / Valves 4 2nd February 2006 07:04 PM
Liquid silicone filled vibration isolators? rickmack Car Audio 0 26th October 2004 07:01 PM
Copyright ©1999-2013 diyAudio
