My Scan-Speak 3way Tower (Avalon Isis alike)
Old 18th March 2012, 10:34 PM   #11
WaVeInFoRm is offline WaVeInFoRm
still wondering how people cut these perfect holes for drivers, im guessing with a router, but how do you set up the jig, im curious because im making a 3 way sea's tower soon....
Old 19th March 2012, 06:27 AM   #12
LineSource is offline LineSource  United States
LineSource's Avatar
Avalon Isis
1" Diamond Tweeter
7" Ceramic midrange(closer to 6.5")
two 13" Nomex-Kevlar woofers
SENSITIVY = 90 db/watt
Impedance 4 ohms
Frequency resonse 20Hz - 45KHz
Dimensions: H=60", W=14.5", D=17"
Weight = 210 lbs each
The Avalon Isis was designed by the genius Charles Hansen. The cabinet shape can trace its origins to Harry Olson's 1953 paper on reducing diffraction by using a truncated pyramid on parallelopiped shape. Charles believes in sealed woofers tuned to Qtc between 0.5 - 0.6. Ihe Isis uses two 13" woofers with 8 ohms, wired in parallel for a 4 ohms load to obtain 90 db/watt efficiency after baffle step compensation is provided. The Isis Accuton diamond tweeter has a 92db/watt sensitivity. In my opinion, the Isis Accuton 92.5 db/watt C173-6-096E ceramic midbass is the key driver in the design because of it provides both wide bandwidth and high detail resolution. I have not found a 6.5" - 7" 92 db/watt alternative with similar BW and detail. I've been using the 8" Tang Band W8-1808. The Acoustic Elegance Lambda 6.5" and future 8" are under "watch for future production" dreaming.
Accuton 7" midbass highlights:
= 7 inch bass-midrange with high efficiency for 3 way designs
= large sized voice coil with 55mm titanium voice coil former for high midrange resolution
= big, underhung 120mm Neodymium magnet system for very low distortion
= Anti-resonant cutout fills in the ceramic dome provide high damping of the 5 kHz dome resonance
Closed Box design parameters:
Vb: 4.1L, -18dB @ 40Hz, F-3dB: 175Hz, Q: 0.50 (clean transient response)
Your 92.5 db/watt at 4 ohms Scan-Speak AirCirc 6600 tweeter would be an execllent choice.
Your 87 db/watt at 8 ohm Scan-Speak 18w8531g00 midwoofer might be better replaced with the 90db/watt 4 ohm 18w4351G/
In the USA, the 6.5" Acoustic Elegance Lambda TD6M-8 would be a consideration also.
T/S Parameters
Fs: 83hz
Qms: 3.1
Vas: 10.3L
Cms: .45mm/N
Mms: 8.2 g
Rms: 1.38kg/s
Xmax: 3.3mm
xmech: 7mm
Sd: 127 sqcm
Qes: .46
Re: 6.1ohm
Le: .044mH
Z: 8ohm
Bl: 7.5 Tm
Pe: 100W
Qts: .4
qW SPL: 93.5dB
2.83V: 94.5dB
Old 19th March 2012, 07:04 AM   #13
LineSource's Avatar
ShinOBIWAN in the UK is using the OEM limited RAAL 70-20XR ribbon tweeter. The shorter physical height plus wider ribbon might be a better match for a 7" midbass than the production RAAL 70-15D you are considering. You can send him a PM for additional information and purchasing options.
Your Scan-Speak AirCirc 6600 dome tweeter is a very, very good choice, but part of DIY is dreaming.
Old 19th March 2012, 01:14 PM   #14
PandazYa is offline PandazYa  France
Here is a link on how to do perfect circle with a router it's in french but pictures says it all.
La Newbinette - la vraie
As for the 4531g instead of the 8531g, my cousin got a pair in his Reference Monitor project so it's easy to try which one is a better match. But considering I'm going active the 8531g00 wouldn't be a problem.
Old 19th March 2012, 08:10 PM   #15
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Originally Posted by gornir View Post
Woofers:
2x SB Acoustics SB23NRXS45-8 optional 2x ScanSpeak 22W/8857T00
/Göran
I've heard the SS 22W/8857T00 as a single in a TL, and it was very impressive. I like what I heard from it over the SB23 in a different TL.
My 2c,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 23rd August 2012, 10:54 PM   #16
Lusk is offline Lusk  Australia
Lusk's Avatar
Originally Posted by PandazYa View Post
Here is my build with the exact same drivers as yours.
http://www.diyaudio.com/forums/multi...sis-alike.html
They're working in an active setup with xo at 270hz lr12 and 1700hz lr24
They sound like a charm just missing the gloss finish
They look great, do you have any pictures of them together finished up to painting stage?
Old 24th August 2012, 08:13 PM   #17
Here is the top box.
I don't have pictures of finnished woofer box but i'll post them as soon as painting will be done
And this is some painting test:
Old 1st September 2012, 10:34 PM   #18
and here is some pics with the woofer box:
Old 1st September 2012, 11:48 PM   #19
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
Beautiful work Pandazya. What type of finish are you going for?
Old 1st September 2012, 11:57 PM   #20
Hi David Gatti,
I'm still not sure about the finnish yet but it will be gloss white or anthracite grey like the Wilson Audio Sasha probably.
My Scan-Speak 3way Tower (Avalon Isis alike)Hide this!Advertise here!
High-end 3-way active Avalon look-alike fgroen Multi-Way 47 15th November 2013 05:55 PM
FS: Scan-Speak Illuminator d3004/60200 Tweeters, Scan-Speak Discovery 10f Midrange bikinpunk Swap Meet 1 27th September 2010 04:13 PM
scan-speak 3-way dre73 Multi-Way 1 18th November 2005 02:05 AM
Scan-Speak Madmike2 Multi-Way 8 24th September 2005 08:25 PM
New vs. old Scan Speak? Mr Ekan Multi-Way 1 5th April 2004 10:50 AM
