What crossover type ? - Page 3 - diyAudio
Old 18th March 2012, 11:49 AM   #21
I think something like 2khz secoond order would be a good starting point if you are happy to try a parallel crossover. The waveguide should hold directivity that low, and the woofer isn't beaming too badly there (atleast from what I see in the datasheet).
Off-axis measurement atleast at 30 and 60 degrees will be needed to get a good match and will also give a better picture whats going on with the current setup.
I would do as Shaun says, set up the target curve and try to match it. LspCAD allows you to do this.
Old 18th March 2012, 11:59 AM   #22
I did try quite a few parallel, second-order crossovers before trying the AR-SXO, but they were always a bit dull. Vocals weren't alive and didn't project like the AR crossover.
I'll try to set-up a target curve and see what happens.
Old 18th March 2012, 12:04 PM   #23
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by fatmarley View Post
Here's the crossover:
You do seem to have departed quite a lot from Acoustic Reality's design there. Bigger bafflestep coil, higher resistance value and perhaps too small a coil in front of the (Le=100uH?) tweeter. The extra, smallish 2.2uF capacitor is going to affect damping a lot too. I wonder what the impedance looks like?
AR-SXO - Acoustic Reality - Designed and built in Denmark
I also wonder if Ben Shaffer's 2nd order design might be better for what you are actually doing:
Tips! Volume 3, Section B.. Series Xovers.... - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com
Or you work with Rod Elliott's 1st or 2nd order butterworth slopes, which are constant resistance and allow you to separate out the bafflestep correction as a series LR circuit before the crossover without affecting the Q.
Series vs. Parallel Crossover Networks
No particular recommendation here, just ideas for your modelling.
Best Regards from Steve in Portsmouth, UK.
Old 18th March 2012, 12:45 PM   #24
Here's the impedance:
Cheers for the links. I'll have a look at those...
Old 18th March 2012, 01:06 PM   #25
system7's Avatar
...snip
HaHa, I mean this in the nicest way, but that's a bit of a horror really, isn't it?
Something going badly wrong at high frequencies...
I've thoroughly read that Troels stuff on the DT-300 in the past, and it looks OK for a simple first order crossover. Vifa C17WH-
The conventional wisdom on series crossovers is you need to use an RC Zobel (say, 8 ohms and 10uF) at least across the woofer, and pad out the tweeter for a flattish impedance. It's quite hard to find out the inductance of the tweeter, but Troels has given the LCR Fs circuit anyway.
I suspect that highish 0.9mH woofer impedance is going to be a pain, but here's hoping.
Old 18th March 2012, 04:52 PM   #26
Shaun is offline Shaun  South Africa
Shaun's Avatar
Is SpeakerWorkshop easy to use?
Yes and no. The difficult part is usually getting the measurements working right. Besides that, working through the example in the help file will get you going in no time. It's not the most intuitive program but, once you get to know your way around it, it's a breeze.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 19th March 2012, 07:58 AM   #27
Yea, it's not looking great on paper, but I don't know how it effects things in reality. Could it be the cause of the rough sound?
To be honest, i'm not sure I want to waste too much time or money on this build because i've decided i'd like to build a 3-way and this enclosure is the perfect size for my new build.
It took a long time to get an acceptable sound from my current speakers, but from what i've learnt, I think I should be able to get there a lot quicker now (getting the BSC right was what wasted the most time).
Old 19th March 2012, 08:00 AM   #28
Cheers. I'll have to think about it...
Old 21st March 2012, 05:42 AM   #29
system7's Avatar
You sound like you're getting into a sulk about this, fatmarley. You shouldn't.
I've already said your crossover point is too high. You need to be around 2.7kHz. I think that AR-SXO is too purist for what you are trying to do as well. It needs particular drivers to stand a hope in hell of working.
A first or second order LC series circuit is more promising.
You need to be familiar with BSC RL circuits:
Loudspeaker Diffraction Loss and Baffle Step Compensation Circuits
And driver impedance equalisation:
Speaker Zobel / Impedance Equalization Network Circuit Calculator
Here's some modelling I did in TINA-TI which is a free download. The crucial thing to keep track of is the L/C ratio (here 270/15=18) , which is half R squared (36) for butterworth second order curves. You can do Linkwitz-Riley by halving the capacitor value too, but that is not constant resistance and changes the crossover point. The LC ratio relates to the crossover frequency. Because your woofer is high at 900uH, you probably need a Zobel, otherwise you could use the woofer inductance as the second (L2) component in the bass crossover.
Old 21st March 2012, 07:13 PM   #30
Sulk! me!
I was serious about building some 3-way speakers (a case of running before you can walk), but not because i'm not happy with these. I just want more of everything.
Thank's for the links - I didn't realize you could get a BSC calculator. if I have the parts, I may try another crossover (I am curious to see if the crossover can be bettered). I know the crossover point is far too high (in theory) , but it sounds pretty good and much, much better than the second-order electrical (woofer and tweeter), parallel crossover I tried before (phase tracking was very good and I had a nice big null at the crossover point).
Regarding the BSC calculator that you left a link too. For some reason it was miles out compared to what I came up with by ear (1.7mH vs 2.7mH). I'll measure the Re of the driver and see what it looks like then.
I really do appreciate any advice and will post all the details of my 3-way build when I start it.
Crossover Optimization.........what of type component swap boards do you use? Gavinator68 Multi-Way 13 23rd October 2011 11:48 PM
Klipsch type E balancing network (crossover) pair jmillerdoc Swap Meet 0 3rd June 2011 04:20 AM
Snell Type 1 Crossover Rebuild lt_texan Multi-Way 31 23rd January 2011 12:44 AM
Least Audible Midrange Crossover Type? cuibono Multi-Way 67 12th September 2010 09:37 PM
Capacitor type for crossover ThSpeakerDude88 Multi-Way 23 4th August 2007 10:00 AM
Copyright 1999-2017 diyAudio
