What crossover type ? - Page 2 - diyAudio
Old 18th March 2012, 08:58 AM   #11
Originally Posted by awpagan View Post
hmm could be -26db needed my glasses.
do you have the graphs/datasheet for the drivers you are using?
IMHO I would leave the crossover as it is, looks fairly flat at crossover.
Isn't that what your looking for? (ps no space after word for ? mark)
Here's the data sheet for the woofer.
Data sheet for tweter here.
I'm using the tweeter with the waveguide.
I've tried loads of different crossovers and this one sounds best to my ears. The only problem is it's a little rough sounding when you crank the volume up on rock music.
I the problem could be a number of things. I did the Troels tweeter mods (scroll down to the bottom) to the tweeter. I have some standrd tweeters that I'll have to try.
The other thing I think it could be is break-up from the woofer. I only have a coil on the woofer and i'm using it's natural roll-off. Perhaps it's distorting here? (no question mark gap). The woofer is obviously going to be beaming at higher frequencies, so perhaps that's part of the problem? I can't say I can notice the beaming though.
These woofers have a very limited xmax (2mm IIRC) perhaps the woofers are distorting because or that?
I'm using an AR-SXO but with a cap on the tweeter.
Old 18th March 2012, 09:04 AM   #12
Originally Posted by mdocod View Post
Looks like 1st order electrical on the tweeter. Notice the -12dB from 6K down to 1.5K (2 octaves where the tweeter is probably naturally closer to flat), then it turns steeper when the natural rolloff of the tweeter kicks in, increasing the rolloff to something like 12dB/octave accoustic.
The woofer appears to me to be on either a 2nd or 3rd order electrical, I would have to see the response of the woofer without the network in place to know for sure.
Either way it looks like a well thought out x-over for the drivers. Measurement confirms the BSC is close to ideal.
That's good to know. I came up with that crossover through trial and error (and a bit of measuring).
Old 18th March 2012, 09:15 AM   #13
Originally Posted by Shaun View Post
I don't know LSPCAD, but I'm sure it should be able to do this:
Select a crossover target curve. There'll all sorts of options: type; crossover frequency; slope; Q; etc. Try a few and see which matches what you've got. Start with the standard types (Butterworth, Bessel, Linkwitz-Riley, etc.). Easiest would be to identify the slope or closest slope. Then tweak the crossover frequency to bring it closer to your own. Then play with the types to find which transition area (i.e., the area between flat and the slope) matches yours. If, after this, you don't yet have a perfect match, it means that your crossover is not one of the standard types, and you may then have to use a custom option to get the target to match your crossover. But in this case it becomes a more complex description (as opposed to, say, 2nd order Butterworth).
I don't think you can do that in LspCAD. It's quite a basic program with a shallow learning curve (that's why I bought it)
I have been tempted to download Holmimpulse. JustMLS (comes free with lspCAD) seems ok to me, but i'm interested to know if Holm would be better in some way.
Old 18th March 2012, 09:28 AM   #14
Shaun is offline Shaun  South Africa
Shaun's Avatar
Are you sure there are no target curves in LspCAD? I find that hard to believe. Nevertheless, you should be able to do the same in SpeakerWorkshop, which is free.
HOLMImpulse does not have crossover design functionality.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 18th March 2012, 09:33 AM   #15
system7 is offline system7  United Kingdom
system7's Avatar
Without knowing the series crossover values, or much at all really, it's a bit hard to comment, but 4kHz seems a bit high for an 8" paper bass to be working at. Can't you get it down a bit? Say 2.5kHz?
Parts Express: Project Showcase
Might help.
Best Regards from Steve in Portsmouth, UK.
Old 18th March 2012, 09:42 AM   #16
Shaun's Avatar
See the LspCAD example here Sample design . Images show a raw driver measurement, a target curve, and the curve including crossover.
Shaun Onverwacht
Old 18th March 2012, 10:16 AM   #17
Here you go:
Old 18th March 2012, 10:29 AM   #18
Is SpeakerWorkshop easy to use?
Old 18th March 2012, 10:34 AM   #19
Might help.
Here's the crossover:
Old 18th March 2012, 10:38 AM   #20
Thanks for that Shaun. I'll have a good look at that when i've got time
Crossover Optimization.........what of type component swap boards do you use? Gavinator68 Multi-Way 13 23rd October 2011 10:48 PM
Klipsch type E balancing network (crossover) pair jmillerdoc Swap Meet 0 3rd June 2011 03:20 AM
Snell Type 1 Crossover Rebuild lt_texan Multi-Way 31 22nd January 2011 11:44 PM
Least Audible Midrange Crossover Type? cuibono Multi-Way 67 12th September 2010 08:37 PM
Capacitor type for crossover ThSpeakerDude88 Multi-Way 23 4th August 2007 09:00 AM
Copyright 1999-2017 diyAudio
