What crossover type ? - Page 12 - diyAudio
Old 15th April 2013, 12:07 AM   #111
AllenB is offline AllenB  Australia
The fundamental sound of the driver size, their baffling and directivity is something you have limited control over with the crossover. In this case the directivity will narrow, then widen and narrow again with increasing frequency. You can choose your compromises but probably not 'fix' it with the crossover.
This is over and above driver selection (eg. replacing with like types that handle a particular range better).
Although I don't know how much of an effect your particular waveguide is offering, horn like devices tend to have issues at their lower end such as a mouth reflection, with issues like 'honk', and a standard caution would be to avoid using them low enough where waves would pass through them as if they are not there due to their size.
Old 1st May 2013, 01:08 PM   #112
And here's the frequency response with the current 2.4k crossover:
This is 0, 15, 30, 45, and i've included the 60 degree off axis response.
Old 1st May 2013, 01:10 PM   #113
And for comparison. This is the previous AR-X0:
Old 1st May 2013, 01:23 PM   #114
I took the speakers outside and hoisted them of the floor to try and get a good measurement of the lower frequencies. The bottom of the woofer was 2.4mtrs off the ground and according to an online floor bounce calculator - If I set the gating to about 10ms I should get accurate results down to 45Hz. Here's what I got:
Why have I got a 6db bass boost? I was expecting to see a flat'ish response or maybe +/- a couple of db but not +6db! They don't sound bass heavy and i'm sure if I removed the 6db bump they'd sound terrible.
Old 3rd May 2013, 11:33 AM   #115
It seems my concerns were probably greater than required. The point about the acoustic nature of the speaker may be food for thought in the future. In the meantime yourself and Steve seem to be nailing this one quite well.
Are you still noticing a harshness? With some speakers a slight downward tilt to the treble is required.
Old 3rd May 2013, 12:01 PM   #116
There's not even a hint of harshness now and I think they sound great. Problem is, I have the bug and want to build more speakers...
Old 3rd May 2013, 12:02 PM   #117
I'm still confused by the 6db bass hump - and due to the lack of response I assume everyone who has looked doesn't know why it's there either. I've got a pair of Mission M70 and some Philips speakers that came with a mini system. If I measure them and they have a large bass hump too, then I guess it must be a problem with the mic or calibration file?
Old 3rd May 2013, 07:39 PM   #118
This could be for mounting near a wall. About 20", I'd think.
Old 3rd May 2013, 09:49 PM   #119
I don't understand what you mean. Could you explain?
Old 4th May 2013, 03:45 AM   #120
A reflection of that length could cut a little at 160Hz and boost the lower bass.
Crossover Optimization.........what of type component swap boards do you use? Gavinator68 Multi-Way 13 23rd October 2011 10:48 PM
Klipsch type E balancing network (crossover) pair jmillerdoc Swap Meet 0 3rd June 2011 03:20 AM
Snell Type 1 Crossover Rebuild lt_texan Multi-Way 31 22nd January 2011 11:44 PM
Least Audible Midrange Crossover Type? cuibono Multi-Way 67 12th September 2010 08:37 PM
Capacitor type for crossover ThSpeakerDude88 Multi-Way 23 4th August 2007 09:00 AM
Copyright 1999-2017 diyAudio
