Newbie working on his first 2-way project.
I made a mistake calculating port length and now my cabinet doesn't have enough depth for the correct port. Do I have any options? What should I do? Thanks in advanced! |
#2 |
Speakerholic
Hi Scar,
Can you put a bend in it? |
#3 |
That's a good suggestion Cal.
But does someone make a port with a bend that I can order? I've never thought of making my own port before. |
#4 |
Speakerholic
I've heard of adjustable length ports but if you want a bend in it, you might have to consider making it yourself.
#5 |
A little pricey when all put together, but an option...
Dayton Audio PT4-MFE 4" Male To Female Elbow 268-334 |
#6 |
#7 | |
Easy to cut with any saw, start a bit long and cut down a bit at a time until you are at the desired tuning, which can be verified by the cone moving the least when a tone is played at Fb. |
#8 |
Thank for all the response!
Making a port is probably my best bet at this point. |
#9 |
Probably your port diameter is too large giving an impractical length. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#10 |
Sreten is right, go for smaller diameter port...
| Port lengths for 2-chamber 2-port bandpass | Circlotron | Subwoofers | 12 | 15th February 2011 12:09 AM |
| Slot port vs circular port equivalence | Brisso57 | Multi-Way | 12 | 21st February 2009 02:38 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| rear port vs front port | Jimmy154 | Multi-Way | 22 | 6th March 2004 08:38 AM |
