Is this really possible? - diyAudio
Old 1st March 2012, 08:50 AM   #1
sardonx is offline sardonx  Canada
Default Is this really possible?
I'm searching for a small woofer (4") to use in multiples to cover the approximate range of 60-300 hertz in a very slim tower. My goal is high efficiency. I stumbled upon this driver..
Fane International Studio Series 5" Professional Full Range Woofer - 50W RMS | STUDIO 5FRK | Fane International
FS=58hz, Sensitivity 92dB. Is that even possible for such a small driver? Seems too good to be true.
The End
Old 1st March 2012, 09:34 AM   #2
frugal-phile(tm)
planet10's Avatar
It is a 5", probably possible.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st March 2012, 10:13 AM   #3
lduarte1973's Avatar
see if you like this one , faitalpro from italy
FaitalPRO - Professional Loudspeakers Made in Italy
Old 1st March 2012, 10:16 AM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
I think there is no way you are going to get 92 dB with that single
driver. Personally IMO the more sensitive the speakers are, the
crappier they sound. If I were to build really sensitive speakers,
I'd do it with PA drivers.
Old 1st March 2012, 10:17 AM   #5
tiefbassuebertr's Avatar
For me this is a high efficiency midrange:
Fs 180 Hz
Re 7.2 Ohm
Qes 0.59
Qms 2.70
Qts 0.48
Vas 0.93 dm^3 (0.033 ft^3)
Sd 94.3 cm^2 (14.6 in^2)
Mms 8.4 g
perhaps this transducer is helpful:
SPH-75/8
or
SPH-75/4
or
http://www.faitalpro.com/products/sc...p?id=401010100
But I wouldn't expect good results in a very slim multidriver tower in general and also inside the range between 60 and 300 hertz.
If your goal isn't special design and only high efficiency, use the Studio 12L from Fane Acoustics
http://www.fane-acoustics.com/prod_details.aspx?pid=174
Old 1st March 2012, 10:39 AM   #6
yes more a midrange than a woofer
Old 1st March 2012, 10:47 AM   #7
see this beyma 5" 91 db
http://www.usspeaker.com/beyma%205MP60n-1.htm
5MP60N - Beyma 5 inch bass/mid frequency loudspeaker - Europe Audio
i would never use this without subs
Old 1st March 2012, 12:36 PM   #8
Different Beyma: http://profesional.beyma.com/ingles/pdf/5P200Fe.pdf
Old 1st March 2012, 12:56 PM   #9
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Look at the datasheet, the 92dB rating is obviously a mis-print.
Old 1st March 2012, 02:07 PM   #10
expert in tautology
bear's Avatar
How many "multiples"?
As you parallel drivers the effective sensitivity goes UP.
Look at some line array speakers...
...and why to only 300Hz. and not higher?
The pdf says 90.1 db/spl
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Copyright 1999-2017 diyAudio
