h-frame visaton b200 + alpha 15 - diyAudio
Old 29th February 2012, 08:05 PM   #1
Send a message via Skype™ to goccolo65
Smile h-frame visaton b200 + alpha 15
hi at all,i am italian,and is my first time i write in a forum, and i am non practice here.
The question is about an open baffle that i have built from the site of m artin king, an h-frame design, using one alpha15a and one visaton b200.
At the moment i use 1,5w triode ampli for b200 , a behringer crossover and a nad for the power the alpha. Now i wish suggest, for a passive crossover , i mean the value and schematic of choke , or cap or resistor .
in the mjk project http://www.quarter-wave.com/Project08/Passive_Crossover.pdf"
Martin use goldwood and jordan, and i think are not the same value of components .....or i am wrong?
and also....a simple tweeter for this OB?
sorry for my bad english
ciao
Old 29th February 2012, 09:18 PM   #2
You can get the values for the B200 from the Visaton no-box:
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 2nd March 2012, 02:21 PM   #3
very intersting link , thanks
and which tweeter do you suggest ?
Old 2nd March 2012, 02:55 PM   #4
picowallspeaker's Avatar
Hi , are you from Florence ? In that case we can meet each other
You can try also a line level crossover , by decreasing the value of the capacitor at the input of your amplifier .
I see that visaton b200 is rated at 96 dB sensitivity , so you'll need a tweeter that makes the same 'noise' ! I know only the Audax TW025 line that has a silk soft dome rated at 96 dB ; Sica makes a good one rated at 94 dB for 1/3 of that price ,around 20 €.
Old 2nd March 2012, 04:09 PM   #5
hi pico, near florence.The sica is the Z009220 - TWEETER SICA 80W, 8 Ohm, 93dB ,cupola in seta trattata ?
DOME TWEETER 80W 8Ω 93dB
Cod: SIC-Z009220
Cod: SIC-Z009220
Cod: SIC-Z009220
Old 2nd March 2012, 07:08 PM   #6
yes ,that's the one .Now , it occurs to my mind that Sica has a new line, with neodimium magnet , which is slightly more efficient ,about 94,5 dB .
It's the one with the crossed wire for protection of the dome .
Someday we'll meet...
Old 5th March 2012, 03:50 PM   #7
thanks pico, i am searching now ...... i have also 4 audax ht210a2 , from project the burlotte, and sometimes change with visaton .... there is no so much difference..the b200 are a little better i know. i have also other 2 alpha15a more, so i could made one other h-frame with 2 audax ..... but, are you from florence?
ciao
Visaton B200 borispm Full Range 29 18th August 2015 02:00 PM
Visaton B200+Eminence Beta 15=OB! Vix Full Range 148 14th December 2011 06:43 PM
Visaton B200 - What to do? AuroraB Full Range 11 27th September 2010 07:25 PM
Visaton B200 / Alpha 15a - What design?? aquapiranha Full Range 30 1st April 2010 08:45 PM
Visaton B200 in Alpha TL Andrewbee Full Range 15 15th July 2005 05:04 PM
Copyright ©1999-2017 diyAudio
