Partially faulty bass driver
Old 29th February 2012, 02:07 PM   #11
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by dmsims View Post
With regards to the basket - it's straight
I took the pic at wide angle (macro) and there is a bit of barrel distortion
Then the problem is as described in #3 or as Sreten said the coil has delaminated due to excess heat and jammed in the gap.
The problem as described in #3 can be fixed without taking the speaker apart, a messed up voice coil requires a recone, generally all the moving parts of the speaker.
The back plate only has to move a fraction of a milimeter for the pole piece to pinch the coil, examining with a magnifiying glass may be needed to determine if that is the case.
Old 29th February 2012, 05:52 PM   #12
puppet is offline puppet  United States
It only distorted that one element in the picture ... nothing immediately adjacent to it? I can see the fuzzy corrosion between the bend and the outer frame .. matches the fuzz all over the basket .... is that a photo anomaly as well?
Old 29th February 2012, 05:55 PM   #13
simon7000 is offline simon7000  United States
Try moving the cone from the narrow point at the rear spider support. If you can move it around and free up the cone then it is fixable. If not you will need a recone kit.
Old 29th February 2012, 06:05 PM   #14
dmsims is offline dmsims  United Kingdom
When you say distorted are you referring to the foam gasket ? - (just to the right of black metal outer)
No the corrosion is crystalline and brushes off
Old 29th February 2012, 07:09 PM   #15
No, the chrome basket. Everything else around that appears "straight". You can see the corrosion crystals between the bent basket and the outer (black) gasket? frame? .. whatever that is. How could one see that (crystalline corrosion) in between there if the basket wasn't bent out of the way enough to see it?
(shrug) According to your pic's .. it looks to me like that chrome basket is bent. That will tweak the cone enough to screw up the voice coil tolerances. That's why the cone is stuck. VC is trapped.
Old 29th February 2012, 07:41 PM   #16
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
This is the part my eyes can't quite sort out. It looks like it was dropped or something.
File Type: jpg Screen shot 2012-02-29 at 12.38.47 PM.jpg (30.5 KB, 85 views)
planet10 needs your help:
Let's help Ruth and Dave
Old 29th February 2012, 09:11 PM   #17
This is the section of the photo I'm talking about:
Old 29th February 2012, 10:21 PM   #18
OK I can sort of see what you are saying in the picture but nothing is bent anywhere
The Seas distributor who I spoke with today described the frame as a "circle with ears on" - it's not a circle
Old 1st March 2012, 01:36 PM   #20
Speakerholic
Cal Weldon's Avatar
If it's shaped liked this, it's called a pin-cushion frame.
File Type: jpg Screen shot 2012-03-01 at 6.35.25 AM.jpg (79.4 KB, 61 views)
Partially faulty bass driverHide this!Advertise here!
What Bass/Mid-bass driver for me? timreeves Multi-Way 4 17th March 2011 12:09 AM
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Little Dot MKIII, faulty driver tube, GE5654 alternative in the UK? markiemrboo Tubes / Valves 6 6th November 2007 11:34 PM
faulty driver? testarossa2k Full Range 9 20th September 2007 10:11 PM
