Old 28th February 2012, 02:38 PM   #1
Default Please recommend Hi-Fi speakers for JBL MX1500 tower
this is all data and my pictures found about this towers
https://picasaweb.google.com/1016749...8341/JBLMX1500
https://www.axacter.com/mx1500.pdf
nominal Impedanse 4ohm
rekomended amp 10-125W
Freq 40Hz - 25kHz
Sensitivity 90dB / 2.8V / 1M
internal volume of 50 liters 220x260x870 thickness of board 1.5
crossover 900Hz 3.5kHz
woofer A0708A 210mm woofer 25mm voice coil 3.4ohm
mid A0704A 100mm 20mm voice coil 3.0 ohm
tweter A0701A 5.7 ohm
port tube 70 mm diametr x 145mm
Old 28th February 2012, 03:12 PM   #2
The tweeter is an Audax, available from madisound.
Refoam the bass units and sort out the pushed in dustcaps.
Remove and replace the dustcaps if you have to.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 29th February 2012, 11:10 AM   #3
woofer maybe Динамик НЧ Visaton W 200 S/4 (1 шт.) ????
Old 29th February 2012, 11:22 AM   #4
Are the mids and tweeters working?
Old 29th February 2012, 01:00 PM   #5
yes all speakers is good but need replace foams for woofers and maybe caps
i have set
MX1500
MX300
i want to use this boxes and replace the speakers with something better )
File Type: jpg CameraZOOM-20120225194452623_resize.jpg (640.2 KB, 44 views)
File Type: jpg CameraZOOM-20120225194604123_resize.jpg (821.4 KB, 43 views)
File Type: jpg CameraZOOM-20120225194616903_resize.jpg (562.7 KB, 40 views)
File Type: jpg CameraZOOM-20120225194651759_resize.jpg (541.4 KB, 38 views)
File Type: jpg CameraZOOM-20120225195016881_resize.jpg (642.3 KB, 39 views)
File Type: jpg CameraZOOM-20120225195120839_resize.jpg (326.7 KB, 4 views)
File Type: jpg CameraZOOM-20120225195137059_resize.jpg (494.5 KB, 3 views)
File Type: jpg CameraZOOM-20120225195215538_resize.jpg (615.2 KB, 4 views)
File Type: jpg CameraZOOM-20120225195440666_resize.jpg (388.2 KB, 5 views)
Old 29th February 2012, 01:15 PM   #6
Pics mx1500
File Type: jpg CameraZOOM-20120225125250684_resize.jpg (156.1 KB, 6 views)
File Type: jpg CameraZOOM-20120225125501240_resize.jpg (133.4 KB, 4 views)
File Type: jpg CameraZOOM-20120225125804882_resize.jpg (170.4 KB, 2 views)
File Type: jpg CameraZOOM-20120225190131654_resize.jpg (175.9 KB, 1 views)
File Type: jpg CameraZOOM-20120225190141107_resize.jpg (180.2 KB, 1 views)
File Type: jpg CameraZOOM-20120225190204032_resize.jpg (211.3 KB, 2 views)
File Type: jpg CameraZOOM-20120225190221418_resize.jpg (156.6 KB, 4 views)
File Type: jpg CameraZOOM-20120225190508521_resize.jpg (178.3 KB, 4 views)
File Type: jpg CameraZOOM-20120225190518449_resize.jpg (161.4 KB, 5 views)
Old 29th February 2012, 01:44 PM   #7
picowallspeaker's Avatar
The membrane in the last two pics is damaged. I fear it has to be changed , too .
Maybe a pair of Dayton DC 250 would be ok ,for the 3 way ...at about 30 $ each .
Check if there are also 4 Ω models , as I see now that the MX 1500 it's rated at that impedance
Old 29th February 2012, 02:06 PM   #9
So you can find any good 25 cm for car ( = 4 Ω ) in your vicinity , if available .
Old 29th February 2012, 02:24 PM   #10
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
The simple route is to have damaged drivers repaired to as close to original stock as possible, and replace aging caps with equal value modern equals to get things back into spec. These 2 steps would result in the most amount of useful refurb for the least amount of effort. The result would be perfectly functional speakers, roughly as good as they ever were. I haven't a clue as to how "good" they were originally so whether or not a complete re-engineering is likely to produce a better result is unknown to me.
On the other hand, I see this as some very plain boxes that could achieve something potentially better with a long list of modifications. Internal bracing, dampening, modern drivers with potentially lower distortion that can handle more appropriate x-over points to maintain acceptable off-axis response. There is a lot of opportunity there to improve things IMO. Many folks will disagree, for good reason. You should weigh potential gamble of a re-engineered design against going back to what they were and decide which you feel is your best option.
Was looking into building some Tower Speakers, but then . . . Cursh Introductions 3 10th October 2011 05:16 PM
Help with building 2 tower speakers Izzy25 Multi-Way 3 7th July 2010 01:35 PM
Recommend a DIY full-range hi-fi speaker better than a 2/3-way one. cirrus18 Full Range 34 13th December 2008 04:09 PM
I have a pair of JBL control 5 speakers, which valve amp design you recommend? ultrapato Tubes / Valves 4 21st July 2005 03:25 AM
Please recommend hi-fi speakers rudy2 Multi-Way 8 22nd February 2004 10:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
