Smallish IB setup - diyAudio
Old 25th September 2003, 10:45 PM   #1
Timn8ter's Avatar
Default Smallish IB setup
This may seem unusual but, I have a room that is primarily for receiving guests and chit-chat, not serious music or movie watching and I'd like to provide some low to moderate level music. My wife wants an unobtrusive system so I'm going to build some small full-range cubes and mount them in the corners near the ceiling. I'd like to have a little low end too, but without the box in the room. So, I have some (4) high quality 8" woofers I'd like to put in an IB in the attic above this room. Since I'm not going for high output levels will the small diameter of the drivers create any serious problems? The transition box will be a 12" cube.
Old 26th September 2003, 04:33 PM   #2
Timn8ter's Avatar
Silence means approval.
Old 26th September 2003, 07:41 PM   #3
RHosch is offline RHosch  United States
The only "problem" is that they will be limited in output and extension, just as they would in practically any other alignment/enclosure type. Since you're not expecting Earth-shattering bass, you will probably be very pleased with the result. Just don't overdrive them... since there is no acoustic suspension to help control cone motion they might bottom out at highish power levels.
Sounds like a good plan, and high on WAF. Enjoy!
Old 26th September 2003, 09:55 PM   #4
Timn8ter's Avatar
Thanks, that confirms my suspicions. I was really hoping to have another audio room but I guess I have to compromise since I've pretty well taken over the whole basement at this point.
Old 27th September 2003, 07:02 AM   #5
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
cover their rears with a layer of 2" open cell foam. it might help.
...still looking for the holy grail.
Old 27th September 2003, 02:11 PM   #6
Timn8ter's Avatar
I've done that before, but not with speakers.
Interesting idea. It's the kind that's easy to experiment with.
Smallish rear back horn design? suposs Full Range 21 14th May 2009 07:28 PM
Smallish chassis feasible? Multiple pics mashaffer Tubes / Valves 13 21st July 2008 01:33 AM
Reccomendations for smallish, cheap sub for FR drivers. Spasticteapot Subwoofers 7 10th November 2006 05:23 PM
cheap sub for smallish enclosure jkamps Multi-Way 0 1st August 2003 02:16 AM
Copyright 1999-2017 diyAudio
