Replacing damage tweeters of the Infinity IL60, need help - diyAudio
Old 22nd February 2012, 04:53 AM   #1
Default Replacing damage tweeters of the Infinity IL60, need help
I just acquired this pair of Infinity Interlude IL60 with tweeter on both speakers damaged. I bought and installed a pair of Dayton RS28F-4 tweeter to replace the original tweeter. However, the problem is that the tweeter level is kinda low compares to the mid-range and the woofer. Is there any way I can boost up the tweeter level? I read somewhere on this site that adding large capacitor will increase response at tweeter low end.
I think I made a few mistake by choosing the Dayton RS28F tweeter. First of all, the frequency response of the IL60 is 28hz-22khz, however, the Dayton RS28F tweeter frequency response only go up to 20khz. Secondly, the Sensitivity (dB) of the IL60 is 89dB, but the Dayton tweeter SPL is 88dB. Could that 1dB smaller makes the difference? Can I still add a cap to in increase response of tweeter at low end to increase it by 1dB or maybe 2dB?
Old 22nd February 2012, 05:34 AM   #2
strawberry's Avatar
You can bypass the resistor for the tweeter on the crossover. Bypass with wire or 1 ohm to begin with. Listen.
Old 22nd February 2012, 02:10 PM   #3
strawberry's Avatar
I forgot to write that you must let the tweeters play 24 hours of music before you know how loud they are. They will get louder.
Old 22nd February 2012, 03:28 PM   #4
Inductor's Avatar
Possibly the impedance is wrong also. Always try to match impedance of the original (if you don't want to end with something different, like changing to a new crossover design when applicable).
Old 22nd February 2012, 10:34 PM   #5
I have played it for more than 40hrs by now. The speaker is rated 8ohm but the original tweeter is 4ohm so I replaced with the Dayton tweeter which is also 4ohm.
Old 22nd February 2012, 10:38 PM   #6
Also will the tweeter volume level be higher if I use one with a higher sensitivity level, let say SPL 91dB or higher for example??
Old 23rd February 2012, 12:02 AM   #7
strawberry's Avatar
You can make this work. Look at the crossover. There should be a white elongated thing there, a resistor. Try putting a wire from end to end of it. Look at the value of the resistor while you do the wire thing. If there are two resistors, put the wire over the resistor with the smaller value. Test play at very low volume. If there is no sound from the tweeter, abort testing.
Old 23rd February 2012, 11:03 AM   #8
Inductor's Avatar
That's good. Back to what strawberry said.
Yes higher sensitivity level would give more output. Look also at constant curve output, or sound quality (similar to original when possible).
Old 25th February 2012, 07:47 AM   #9
This works for me. I open the crossover and found 2 resistors, one is 3.3ohm and one is 1.8ohm. I bypassed the 1.8ohm resistor since it's the lower one. The tweeter volume is definitely louder. I think the sound is good right now. I'll let it play for a while. If the tweeter gets louder I can always replace the 1.8ohm resistor with a lower one but for now I think I'm happy with it. Thanks.
Old 25th February 2012, 05:39 PM   #10
strawberry's Avatar
If you don't feel like analyzing the crossover for even better sound but just want to wing the resistor load, your next step should be to buy two 2 ohm resistors if you want less volume from the tweeter. Let those 2 ohm resistors replace the wires you attached. 1.8 ohm and 2 ohm in parallel will be about 1 ohm, a common load. If you take picture of your crossover and upload it it would help solve your problem.
Infinity 475a water damage detourbeach Class D 2 26th October 2010 11:13 PM
Replacing focal tweeters? Or new speakers? jonnyboy1617 Multi-Way 2 5th May 2010 12:53 PM
Infinity EMIT tweeters argonrepublic Multi-Way 1 4th July 2005 02:12 AM
Replacing tweeter with one from a different model? (Infinity Kappa -> Interlude) krisztoforo Multi-Way 2 25th January 2004 03:18 AM
Are the Infinity EMIT tweeters good? Hybrid fourdoor Multi-Way 2 12th July 2003 03:01 PM
Copyright 1999-2017 diyAudio
