Banned
my speakers are about 89db. How much of a voltage difference at the amp output between the left and right channel can be heard and enough to cause a shift in image?
#2 |
At around 4000 Hz, where the ear is most sensitive, an almost unmeasurable voltage (less than 1/100th of a volt) difference could cause an "image shift".
A tweeter or midrange hooked up opposite polarity from the other can cause a shifting image, stereo sources stay more "still" mono sources "waver". |
#3 |
Banned
but if 0.01 volts can cause an image shift what chance is there of attaining a match?
#4 | |
If you have an amplifier that randomly shifts in voltage amplification, it should be repaired or replaced if it bothers you. I would doubt that an "image shift" has anything to do with amplifier voltage, but everything to do with program, speaker, and hearing frequency response deviations. If your speaker placement and the room are not symmetrical, the reflected room sound from each will be different, and will vary with frequency, adding further to "image shift". |
#5 |
A very bad start to answering the OP's question, and a stupid number, 1/100 of a volt, which is meaningless without defining the real level. The numbers to use are dB, 1dB will cause a shift, 3dB very noticeably, 6dB very severely and 10dB you might as well disconnect one speaker. 1dB is about 13% difference between the channels. 10% is a reasonable number to say it won't make much difference, though golden ear types might say lower, say 6% or 0.5dB, if your speakers match to that level. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#6 |
Yes, those are % voltage. So the .01 volts is meaningless. If your listening quietly and the signal level is only .05v, .01v will make a differance. If its 20bd louder at .50v .01v wont matter.
#7 |
Banned
#8 | |
Banned
seeing on the multimeter. So what does 0.1 volt translate to in db? I used a 1khz sine wave signal going into the amplifier. |
#9 | |
To translate voltage into dB, or what you hear, dB SPL, you have to know the speaker sensitivity, and the distance and level listened at. Doubling voltage will result in a 6 dB level difference, as Sreten points out, that is a large level difference. However, I would not describe a large level difference as an "image shift", you need to describe what your perception of an "image shift" is when it comes to sound . Sound pressure - Wikipedia, the free encyclopedia At 1K, -8 dBSPL is roughly the sound of a mosquito flying 3 m away. A very small fraction of a volt in to an 89 dB 1 watt one meter sensitivity speaker could equal that level, as a professor you may be able to figure that out, somebody just did in the thread titled: “A Test. How much Voltage (power) do your speakers need? |
#10 |
But dB is what matters, as already explained, so you need a percentage difference, as also explained. You are measuring two voltages; just calculate the percentage difference between them.
| Where to get balance controls? | Glowbug | Solid State | 5 | 26th October 2006 08:06 AM |
| Quad balance | ginsner | Solid State | 4 | 16th August 2006 08:04 PM |
| Readjusting balance | Jasmeleg | Solid State | 3 | 12th September 2005 10:39 AM |
| Why is Q balance required | goldyrathore | Multi-Way | 6 | 16th May 2004 11:04 PM |
| Are Balance Controls Still Necessary? | runeight | Tubes / Valves | 32 | 2nd November 2003 10:47 PM |
