Old 13th February 2012, 06:31 PM   #1
Default DIY 2.1 System - Eekel's Mini + Dayton Audio RSS210HF-4
Hello All
I will start here to present my current status of this DIY project: Eekel's Mini + 8" RSS210HF-4 Subwoofer.
The plan is to go all active. Thus, I will make my own version of thee Eekel's Mini with integrated Hypex AS2.100 amplifier (master + slave). I will have to change the port configuration from round to rectangular in order to accomodate the plate amplifier. Also I plan to put polycarbonate covers on the XOs so I can see them directly from the outside... niiiiice
The subwoofer I get a preliminary design of 17,6 liter closed box with a QTC of 0,634 and F3 of 48,77Hz... I would appreciate if you could comment on this also! All of you who are far more experienced than me for sure...
I will start next weekend and I will put the photos here so I can share my work.
Best Regards
André
Old 10th March 2012, 01:15 AM   #2
News on the construction!
Old 16th March 2012, 12:58 PM   #3
crossover parts arrived!
Old 16th March 2012, 07:42 PM   #4
So I made a template for each crossover, treble and bass, in order to study best component placement and this is the final result!
Old 16th March 2012, 07:44 PM   #5
Speakerholic
Cal Weldon's Avatar
Nice, will you get to listen this weekend?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th March 2012, 07:47 PM   #6
Hello Cal
I still have to make all the connections... Also I still don't have the drivers with me :S
But I am pretty curious on how will it sound... also with the Hypex AS2.100 plate amplifier.
Old 19th March 2012, 12:53 AM   #7
Work goes on... soldering crossover components (bass section)!
Old 19th March 2012, 03:12 PM   #8
Both Crossovers finished 2 pairs of tweeter and bass section
Old 19th March 2012, 06:57 PM   #9
wolf_teeth's Avatar
Default Depends on your usage...
I have measured 2 of the RSS210HF-4, ad here are my measured numbers.
That should help you refine your simulation. FWIW- I use it in 1ft^3, with a 2.5" D x 10.5" L port. Fb/3/10 = 30/26/19 Hz, and good for about 70-100W mechanically.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 21st March 2012, 11:55 AM   #10
Thank's a lot Wolf... I see that there is considerable difference between each driver, although being the same. I generally assume this to be a fail e quality control, no?
Meanwhile I have been searching a few other options for the subwoofer and it appears that the SEAS D1001-04 L26ROY would be also a good choice, which also fits my budget!
I am using UniBox to model the sub and I come out with a closed box:
Design by Vb and QPhysical Vb24,2lAbsorption, Qa20Leakage, Ql30Alpha, a3,389Vb25,7lFb46,05HzF350,12HzQtc0,649Response peak0,00dBPeak atnone
WHat do you guys think? I want a "stiff" bass but still have some little boominess... Generally I tend to like subwoofer with great "kick" but that can go low without being to boomy...
DIY Electronics Parts - chassis, twisted pear, Dayton audio edjosh23 Swap Meet 15 22nd April 2011 07:40 PM
small closed 1 x 8" dayton rss210hf-4; what amp? erikb1971 Subwoofers 4 2nd January 2011 02:22 PM
Need advice on large Dayton Audio HT system. FE3T Multi-Way 5 29th August 2010 09:40 PM
DIY Mini Op-amplifier for speakers and audio testing EWorkshop1708 Chip Amps 8 6th June 2009 04:21 AM
first diy - dayton reference + rythmik audio mazurek Subwoofers 2 21st October 2005 01:19 AM
Copyright ©1999-2013 diyAudio
