Old 11th February 2012, 07:00 PM   #1
Default strange (?) noise
First, I just have to say that I'm a newbie... and excuse in advance for all stupid things I'm going to ask here below ;-)
I have built my own speakers, using DLS drivers.
From one of my 4" mids, I get a little, but still annoying, noise. The noise is in the lower frequencies. When I put a little little pressure from my finger on the rubber-thing that is holding the membrane, this noise disappears.
I also think (but I'm not really sure) that this noise appears more easilly if I take out the driver from the speaker-box.
Do you guys have a clue?
Thanks!
Old 11th February 2012, 07:08 PM   #2
The speaker baffle may be warped, or the speaker is not properly torqued, warping the frame and causing the voice coil to drag slightly.
Old 11th February 2012, 07:14 PM   #3
Is there anything I can do if, say, the frame is warped?
Old 11th February 2012, 07:46 PM   #4
system7 is offline system7  United Kingdom
system7's Avatar
Yup, turn the speaker upside down.
They often are misaligned, and having it upside down cures it.
Best Regards from Steve in Portsmouth, UK.
Old 11th February 2012, 07:53 PM   #5
Speakerholic
Cal Weldon's Avatar
If it is a warped baffle, try backing off the screws a bit. If that's the cure, add a gasket.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Strange Noise From Amp sportoghese Tubes / Valves 5 2nd July 2010 09:26 PM
Strange noise...? Skorpio Solid State 16 6th August 2007 06:21 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 10:14 PM
Strange noise form lm3875 velikan Chip Amps 2 1st March 2005 04:45 PM
About strange noise from my amp! Otherwise Solid State 6 11th September 2003 12:12 PM
Page generated in 0.07779 seconds (86.08% PHP - 13.92% MySQL) with 10 queries
