Old 10th February 2012, 12:31 AM   #1
parak21 is offline parak21  Philippines
Default mid driver proposal
which drivers could go up to say 3khz to 4khz but can still go loud? and at the same time can give midbass punchy response as well.
these will be used for 2way configuration paired with a beyma 1' compression driver.
1. http://profesional.beyma.com/pdf/12MI100E.pdf
2. http://profesional.beyma.com/pdf/12MW%20NdE.pdf
3. http://profesional.beyma.com/ingles/pdf/12P80Fe.pdf
4. http://profesional.beyma.com/pdf/SM-212E.pdf
5. http://profesional.beyma.com/pdf/SM-112%20NE.pdf
Old 10th February 2012, 02:47 AM   #2
These are all 12" drivers, so they are going to beam above ~2kHz. If you want to go above 3k and get dispersion close to matching a horn/waveguide, you're going to need a smaller driver.
Old 12th February 2012, 02:01 PM   #3
Default Horns are Narrow Band-Pass Devices
When you use them, you are trading bandwidth for efficiency.
For an all-horn loaded system, plan for a 3/4-way system with each driver covering a one decade (or less) frequency band.
Note that, at the lower bound of each band, the driver becomes displacement limited as horn loading starts its decline.
The mid (voice range: 300-3,000 Hz) band will be the biggest challenge. Besides the horn, a phase plug needs to be designed as well. This device is needed to extend the upper frequency limit of an open frame driver when it is used in a horn. For this application, a 6/10" driver with a low [Qts] should be sufficient.
WHG
mid driver proposal parak21 Full Range 2 10th February 2012 06:42 AM
Mid Range driver which one the best? first_1st Multi-Way 18 22nd March 2010 03:58 PM
mid driver DIM Multi-Way 5 29th December 2005 10:26 PM
Proposal: Driver Database for ZMA and FRD Files Rarkov Everything Else 4 4th November 2003 10:22 AM
Mid driver advice (again) Duck-Twacy Multi-Way 4 29th March 2003 08:47 AM
Page generated in 0.07405 seconds (73.12% PHP - 26.88% MySQL) with 10 queries
