#11 |
I actually had these speakers in parallel with another set and a powered sub on the same amp. I had originally measured both paralleled sets and one measured only 1.3 ohms and that got me a little worried about my amp as I was on the 4 Ohm taps (though now I see that DC resistance isn't the proper way to measure).
I'm fooling with the woofer now and I can get a resistance reading on the wires from the speakers tabs into the cone, but not on the tabs themselves so it looks like a simple solder fix. *fingers crossed* |
#12 | |
Most speakers impedance actually drops pretty close to DC resistance at some point in the curve, figure the DC resistance to be safe as far as your amp. |
#13 |
What model are the speakers ? On a 4 ohm tap they shouldn't be used in parallel with anything else, nevermind something that measures 1.3R, is that both parallel ? rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Impedance question | t0mm1 | Multi-Way | 11 | 22nd January 2012 12:48 AM |
| Impedance question | jetbat | Tubes / Valves | 4 | 8th May 2009 06:35 PM |
| Impedance Question | jwatts | Multi-Way | 10 | 2nd June 2006 12:31 AM |
| Another Impedance Question | Sherman | Multi-Way | 25 | 19th March 2004 12:39 AM |
| Question about impedance. | Firebird | Multi-Way | 3 | 8th March 2004 11:01 AM |
| Page generated in 0.06760 seconds (69.91% PHP - 30.09% MySQL) with 10 queries |
