Any currently produced drivers for LS3/5A?
Old 26th October 2012, 09:10 PM   #51
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Not impressed with LS3/5A both KEFs and B&W of same time sounded better. As for KK using LS3/5A for evaluating the subbass performance of various SS amps tells more about the level of sense in the man than the level of bass performance
Old 28th October 2012, 02:23 PM   #52
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by tiefbassuebertr View Post
No hints to currently available Mid-bass drivers near by KEF B110 character (go to post #40)
A good replace is the "Studio 5FR" from Fane Acoustics, but not it's successor
Fane :: Fane Studio 5FR 4? ONLY 74.99
Originally Posted by raul_77 View Post
Falcon Acoustics have a kit for a clone whit very reasonable cost:
FALCON LS3/5a STYLE MINI-MONITOR S FULL KIT
This transducer is either this
http://www.bluearan.co.uk/index.php?id=MON101430
or this
http://monacor.co.uk/products/speake...-5/vnr/101850/
great similarity to that one from Linn's KABER
Old 29th October 2012, 07:28 PM   #53
diyAudio Member RIP
KEF B110 REPLACEMENT SP1003. FALCON F B110 8 ohm. PAIR. MADE IN UK.
Though I tend to agree that the Vifa 5.5" P13WH-00-08 is the classic small mid bass.
rgds, sreten.
Old 29th October 2012, 10:11 PM   #54
rgds, sreten.
very interesting - good advice. Since when this Falcon versions are available?
Old 14th November 2012, 04:42 AM   #55
speakerman19422 is offline speakerman19422  United States
speakerman19422's Avatar
Last I checked the Vifa 5.5' were discontinued.
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
Old 14th November 2012, 01:15 PM   #56
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
The Stirling crossover boards are indeed set up for bi-wiring.
Old 14th November 2012, 06:02 PM   #57
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Originally Posted by Jay View Post
The delay circuit on the tweeter (XT25) of the ZD5? I don't like such circuit. If you had access to a lot of drivers, why not choose drivers combo that doesn't require complex filter? Best speaker always start with best matched drivers.
If you don't like a delay circuit, my Scandivifias use the same drivers without such a circuit, but you have to use a truncated pyramid.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 14th November 2012, 06:05 PM   #58
wolf_teeth's Avatar
Originally Posted by system7 View Post
The LCR notch on Fs is really quite variable. I got 225uF, 0.59mh and 3.7 ohm on published specs at Fs 436Hz.
Using measurements, I was able to be +/-0.5 ohm from DC to 20kHz on the XT25TG30 using a 150uF/1mH/4.0 ohm (resistance + DCR of coil).
Later,
Wolf
Old 14th November 2012, 06:14 PM   #59
wolf_teeth's Avatar
Figured I'd better post my results in contrast...
ZD5:
Scandivifias:
There was some HVAC noise present in the room where the measurement was taken, and the plot should be good to 500Hz or so....
Later,
Wolf
Old 15th February 2013, 01:53 AM   #60
theaudiopath is offline theaudiopath  Australia
You have to ask yourself if the LS 3/5A is so fantastic why are so many people so eager to unload them on ebay? An XT24 TG30-04 Tweeter & a Silver Flute W14RC25 in a reflex tuned slot labyrinth [my coin for an advanced wide band reflex tuning design] with this crossover
will EAT an LS 3/5A in every performance criterion for breakfast forget it by lunch time & turn it into a nicely coiled stool just before dinner. This is my LOWEST performing speaker that would end up as a rear in my future surround sound system. Any takers for a blind listening test to compare your LS 3/5A to this in my neck of the woods? LS 3/5A'S are Nice speakers in the same way that a vintage Merc is nice, but compared to a modern Merc there is simply no comparison performance wise. But if you love that vintage sound go the Falcon they should give superior sound without the stupid S/H pricing for the original
Cheers the path
Any currently produced drivers for LS3/5A?Hide this!Advertise here!
LS3/5A, are there... Mr. dB Multi-Way 53 4th June 2015 12:39 PM
LS3/5a M Gregg Multi-Way 48 5th December 2011 12:18 AM
LS3/5a on Ebay maessen Multi-Way 14 18th February 2011 12:29 AM
LS3/5A Subwoofer aubergine Subwoofers 12 8th July 2008 02:06 PM
bbc ls3/5a audiothings Multi-Way 1 10th December 2007 09:05 PM
Copyright ©1999-2017 diyAudio
