Any currently produced drivers for LS3/5A? - Page 7 - diyAudio
Old 15th February 2013, 05:48 PM   #61
Hi, in answer to your question go to falcon acoustics. It is a British site. They have brand new "B110" drivers at a price. They look like they ought to be really good if you want to reproduce the LS3/5a. I think T27s are not available or anything like them.
Old 15th February 2013, 05:58 PM   #62
raul_77 is offline raul_77  Europe
Well, I don't know if this cabn be interesting, but perhaps the Focal Chorus 705V can be a cheap option:
Doctorjohn Cheaptubeaudio: Audio Reviews and More: HiFi Letter from New York 2009 (4): Focal Chorus 705V, Linn Kan
Old 15th February 2013, 06:37 PM   #63
system7 is offline system7  United Kingdom
system7's Avatar
That was an interesting review, raul_77. Interesting that the old LS3/5A clone, the Linn Kan, which used old Chartwell LS3/5A ply cabinets and B110 units, was so indistinguishable from paper cones. Let's remind ourselves that B110 units went downhill when fire-retardent was added to the bextrene mix.
I do think the 11L Troels Gravesen Paper PL14WJ design is a good modern contender:
Vifa PL14WJ-
It's quite easy to build in the UK, since Wilmslow Audio have a cabinet and crossover PCB that is just PERFECT for 149mm bass and 104mm treble:
Mercury cabinets
In fact Wilmslow offer a driver + crossover kit using the similar (hell, almost identical...) Tymphany Scanspeak 15W-8434_G00 bass and ScanSpeak R2604/8320 tweeter.
MERCURY - Silver
Troels' selection is probably better since the Vifa PL14WJ is a vented bass, which is a good feature IMO. But Vifa and Scanspeak drivers both available at Falcon Acoustics.
IMO, the sliced paper Scanspeak 15W-8530-K00 is a bit overpriced. Why slice a cone, then repair it with glue? A 6kHz peak on the cheaper units is not hard to fix with a notch filter if you want to get fussy. Try 10uF, 0.1mH and 1.5R, and give the treble filter 4uF at the input.
Best Regards from Steve in Portsmouth, UK.
Old 15th February 2013, 08:14 PM   #64
diyAudio Member RIP
Originally Posted by system7 View Post
... Interesting that the old LS3/5A clone, the Linn Kan ....
the Linn Kan is about as far from a LS3/5A clone as you
can get using the same sealed cabinet and bass driver.
Horrible speaker, with no BSC and no midrange peak EQ. Still
it did have its fans - but diametrically opposed to LS3/5A types.
rgds, sreten.
Old 15th February 2013, 09:03 PM   #65
Moondog55's Avatar
Originally Posted by speakerman19422 View Post
Last I checked the Vifa 5.5' were discontinued.
No still available just re-branded, the last ones I saw were labelled Peerless and probably by now relabelled again as Scanspeak and three times the price LOL
I have thought that the notification of their demise was a way of increasing sales, it made me buy 4 extra "Just in case"
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 1st January 2017, 11:12 AM   #66
AJDMGM is offline AJDMGM  United Kingdom
I managed to acquire a pair of LS3/5as, assembled in the Far East by an ex. BBC engineer.
The used drive units and crossovers produced in, presumably, China.
The correct foam lining hadn't been used, so I ordered a set from Falcon Acoustics.
I also fitted some superior terminals, also obtained from Falcon.
After some checking I re-assembled them.
They did sound excellent and running them against a pair of 11 ohms Rogers LS3/5as, it
was difficult to tell them apart.
After some negative comments on Far East manufacturered LS3/5as, it appears that some
are excellent.
For instance, the Rogers 65th. Anniversary model is reputed to be one of best sounding models.
Old 1st January 2017, 08:29 PM   #67
I think the whole LS3 5A thing is fascinating. You got to hand it to the BBC. Turning a production & QC disaster into a marketing success. With one of the most boring and under perfoming "studio monitors" in pro broadcast history. LOL PT Barnum was so SO right!
Old 2nd January 2017, 10:29 AM   #68
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
I heard the LS3/5A the KEF 101 and the B&W DM12. I liked the DM12 best but the KEF 101 was also good (and better than the LS3/5A) with less of that lumpy middbass/lower midrange of the LS3/5A.
The BBC LS3/5A was not meant to be a hifi speaker on stands in a room. They were meant as nearfield voice monitors. If as monitors they highlight flaws in the broadcast of voices it not a bad thing. If they have terrible bass and fall apart playing large ochestral music it hardly matter for their intendend use. BBC designed them as a tool for a specific purpose no blame should befall BBC for shortcomings outside there intended use. The blame should be placed on reviwers who use them to estimate the bass performance of KRELL power amps (Ken Kessler in HFN&RR in the 80s if you do not believe me), or similar stunts.
Old 2nd January 2017, 12:44 PM   #69
Originally Posted by DrBoar View Post
I heard the LS3/5A, the KEF 101 and the B&W DM12. I liked the DM12 best, but the KEF 101 was also good (and better than the LS3/5A) with less of that lumpy midbass/lower midrange of the LS3/5A.
The BBC LS3/5A was not meant to be a hifi speaker on stands in a room. They were meant as nearfield voice monitors. If as monitors they highlight flaws in the broadcast of voices it not a bad thing. If they have terrible bass and fall apart playing large ochestral music it hardly matter for their intendend use. As BBC designed them as a tool for a specific purpose no blame should befall BBC for shortcomings outside there intended use. The blame should be placed on reviewers who use them to estimate the bass performance of KRELL power amps (Ken Kessler in HFN&RR in the 80s if you do not believe me), or similar stunts.
OK, the LS3/5a was not meant to be a hifi speaker on stands in a room.
That doesn't mean that it cannot give musical satisfaction.
They can ( and do ) sound superb on some music, especially female vocals.
No doubt they sound less appealing on rock music and the like.
As for Ken Kessler the less said, the better.
LS3/5A, are there... Mr. dB Multi-Way 53 4th June 2015 12:39 PM
LS3/5a M Gregg Multi-Way 48 5th December 2011 12:18 AM
LS3/5a on Ebay maessen Multi-Way 14 18th February 2011 12:29 AM
LS3/5A Subwoofer aubergine Subwoofers 12 8th July 2008 02:06 PM
bbc ls3/5a audiothings Multi-Way 1 10th December 2007 09:05 PM
Copyright 1999-2017 diyAudio
