Old 3rd February 2012, 07:02 PM   #21
pos is offline pos  Europe
pos's Avatar
If you look at the FR with the marker set at the start of that wiggle you will actually see at which frequencies this breakup is resonating, and also the effect of any crossover you might want to try and measure.
Old 3rd February 2012, 07:12 PM   #22
I'm not at my measurement set up right now, but I will do that later today and post it. Presumably, I'll get the same thing shown in the links above.
Old 4th February 2012, 12:27 AM   #23
Okay, here comes some data. This post: impulse, with frequency responses at various gate times. The key on the freq. response plots also corresponds to the circles on the impulse response. The peak before each gate time is one that makes a significant difference. I only included new gates and responses for the peaks that make a significant difference in response. Time zero referenced on the response plots is the start of the impulse, not the time zero shown on the impulse. The next post will show time windows after the start of the impulse, as requested.
Between gates 1 and 2 in the impulse is the blip that is not a consistent feature. It is something with my cabinets that I should be able to fix.
Old 4th February 2012, 12:41 AM   #24
Here are two responses from time windows restricted to the area of interest. Sorry I had to change the magnitude scale from above. All gates are uniform here and above, btw - no hanning taper. The pink one (I think) is the real subject here, while the blue one includes the cabinet-related thing I should be able to figure out on my own.
I hope you can interpret how this refers to the previous post - it is hard to make this easy to follow!
File Type: png TD15M FR on-axis 35-inches - other gates.PNG (40.0 KB, 278 views)
Old 6th February 2012, 10:03 PM   #25
Anybody? I'm going to see what more I can figure out tonight or tomorrow night. Any tips/ideas appreciated.
Old 6th February 2012, 10:34 PM   #26
tuxedocivic's Avatar
It looks like reflections are getting in once the gate moves past about 2.5ms, as the question about the 2.45ms issue would suggest?? Are you sure you're reflection free more than 1m in all directions? The red response looks useful...
Old 7th February 2012, 03:00 PM   #27
I'm not sure I understand what you're saying - you realize the 2.45ms cannot be any normal reflection, right? If you're saying there's too much other stuff going on to examine the 2.45ms issue, I may need to use a measurement without the 1.7-2.0ms reflection instead of just trying to start the gate after it. I'll give that a try next.
Old 7th February 2012, 08:49 PM   #28
keto is offline keto  Mexico
Hey, I don't know if this is exactly what you're looking for, but here is a shot taken at 9" in a 2 cu ft box and driven by a SET amp, with and without filtering.
Old 7th February 2012, 08:54 PM   #29
Thanks, but not really. I need measurements from farther away, and without smoothing.
Old 8th February 2012, 01:59 AM   #30
Thanks for updating Keto. If you can give me enough details I can try to replicate that. Looks similar to what I'd get with averaged periodic noise, I think.
I'm not having much luck with eliminating the other anomaly above so far. I removed the back of the cabinet, put fiberglass all over the place, and wrapped cork around baffle edges (because that has an effect on the DE250 being tested in the same enclosure). No noticeable change in the impulse, and nothing but fractions of a decibel here and there in the freq. response. So, I figured maybe I'll go back to the other woofer in free air, but that immediately seemed silly - too many other issues to deal with. Not sure what I'll try next. Maybe this is all the same issue as the 2.45ms thing.
Last edited by dumptruck; 8th February 2012 at 02:13 AM. Reason: a little more info
Is the AE TD15M the ultimate mid driver? pk Multi-Way 42 31st January 2012 02:19 PM
TD15M woofer with Geddes 12" waveguide drchait Multi-Way 3 13th October 2011 05:44 AM
Wanted : Acoustic Elegance TD15M TD15LO hum4god Swap Meet 0 10th December 2010 03:45 PM
Large format simple two way TD15M w/TPL-150H or GPA604? ctrevith Multi-Way 38 27th October 2010 07:06 PM
TD15M, does anybody have one willing to donate for Klippel testing? thadman Multi-Way 71 4th September 2009 03:10 AM
Page generated in 0.10236 seconds (78.10% PHP - 21.90% MySQL) with 11 queries
