I am upgrading my 3 way crossover and I consider to get Mundorf superme silver\gold\oil 2.2uf for tweeter high pass and Jantzen Z-superior 22uf for the midrange high pass.
is it ok to mix cap of differnt type\vendor in the same crossover? if yes, does this components match each other? I dont want to hurt the damage the connection betwenn tweeter and midrange. the problem is Mundorf superme Silver\gold\oil are very expensive in the 22uf version, so becuase of that I need to buy other capacitor for midrange high pass without effect the syenrgy between elements Thanks |
#2 |
It's okay to mix and match crossover brands. Your choices are very high end. I hope you have the speaker with exceptional resolution capabilities that those pricey caps will be worthy of!
If not, you'll probably be wasting your money. |
#3 |
I Have Audison THESIS Orchestra Component and Audison HV VENTI amplifier. do you think it worth it?
in addtion, I am considering to replace the Z-superirr with Mundorf MCAP Superme, what you think? Thanks |
#4 |
I'm not at all familiar with that speaker. However, I did a brief search and found it's for automobile application? If so, hey, it's your money!....
#5 |
yes they are super high end togther with the HV VENTI amp. what do you think regard the midrage cap? |
#6 |
the z will be fine.
#7 |
I was just reminding myself what the excellent Troels Gravesen uses in his designs:
PRELUDE Jantzen Superior Z-Cap. ![]() In the days when I worked on submarine cables, polyethylene was considered the ideal dielectric for cables with copper inner and aluminium outer. Entirely passive dielectric, unlike stuff like polyester which has polar molecules which cause molecular resonances at certain radio frequencies. You can imagine, on cables 3000 miles long, this stuff mattered. These capacitors will be metallised film on similarly passive polypropylene, but should work well. Hey, you can upgrade to those pricey mundorf later if you lie awake at night worrying. But I wouldn't. At a certain point, you are being sold snake oil. Last edited by system7; 2nd February 2012 at 01:35 PM. Reason: Added RF comment. |
#8 |
which coil type is recommnded for Woffer low pass,and which for midrange low pass?
#9 |
Leave the woofer coil alone. For the mid, if the current coil isn't air coil, then replace it with air coil with the same mH and as close as you can get to the same DCR. Don't sweat the brand. It just copper wire/foil, etc.....
#10 |
the MID low pass and tweeter high pass are Air core , so as I understand I should not replace them , correct?
the woffers have IRON BARS coil should I replace it? Thanks |
| 3 Way Crossover Upgrade Question | sgerus | Multi-Way | 0 | 15th March 2010 03:06 PM |
| Crossover upgrade help!! | elves1111 | Multi-Way | 7 | 20th July 2009 05:10 PM |
| Crossover upgrade question | serengetiplains | Multi-Way | 3 | 5th May 2009 02:09 PM |
| Upgrade Crossover Network? | bombshell | Multi-Way | 1 | 11th August 2004 06:25 PM |
| Kharma Ceramique 1.o crossover upgrade | nrchy | Multi-Way | 0 | 11th July 2004 02:40 PM |
| Page generated in 0.10996 seconds (80.92% PHP - 19.08% MySQL) with 10 queries |
