Looks like there was some sort of QC problem with the 'keraform' units ( ap 130mn4 -not aerogel) used in the 78/780 range as I've googled and seen that other people had failures. Both of the units in my friend's 78c centre speaker have gone to ~50k ohms, I'm not optimistic about repair - any ideas for drop in replacements now the ap range is not in production?
'We demand guaranteed, rigidly defined areas of doubt and uncertainty!' - Douglas Adams |
#2 |
Falcon Acoustics | The Leading DIY Speaker Parts and Kit Supplier since 1972 sell Audax drivers but they are not cheap. A complete used replacement would probably be cheaper. Willys-hifi on e-pray do cheap decent drivers that may not be ideal but get things going. The 78C claims to be 8 ohms, so it presumably has 2 : 12 to 16 ohm units in parallel or 2 : 3 to 4 ohm units in series. These might work in series: Peerless SKO130 POLY 5" Bass/Mid hifi woofers - 4 ohm! | eBay These might work in parallel : Peerless SKO130 5" Bass/Mid KEF B110 alternative | eBay If the above don't fit because they are too large then in series should fit : http://www.ebay.co.uk/itm/Peerless-L...#ht_4619wt_808 rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 1st February 2012 at 02:25 PM. |
#3 |
Have you tried contacting mission for replacement parts?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#4 |
Thanks guys - will drop Mission a line first and then investigate the suggested alternatives.
Ian
#5 |
From what I can tell Mission sold there inventory of replacement drivers online at amazon.co.uk and this particular driver is no longer available. rgds, sreten, I really don't know know where willys-hifi get there part numbers from. 8" drivers and above are described as usual by the diameter, but below that they mix up cutout and diameter specifications. Ignore the first option, they simply won't fit, 130mm cutout, 160mm dia. The third option will be too small, 100mm/130mm now I've looked into it. The second option should fit, 120mm cutout versus Audax 118mm. Each mounting hole will be less than a mm out, and should not be a problem with the slotted mounting holes and frame. You might need to chamfer the cutout edge slightly. So go for two of these only (in parallel) for a £20 budget fix : http://www.ebay.co.uk/itm/Peerless-S...#ht_4264wt_808
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 1st February 2012 at 09:37 PM. |
#6 |
I wish I'd known about that I'd have purchased some if the prices weren't insane.
#7 | |
There is the rub. The drivers were £18 each * (+P&P) and almost certainly not exclusively bought by those needing replacement drivers, presumably the opposite. So not a great approach to long term customer service IMO. rgds, sreten. * definitely a sell-off price rather than a service replacement price, but now I can't find where I got that price from, so I may be wrong. http://www.amazon.co.uk/Mission-spea.../dp/B0013ISVEA
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 1st February 2012 at 10:06 PM. |
#8 |
I agree selling them off is particularly poor, mission should have held onto them for occasions like these. £18 each is certainly not a lot of money, although one could also say that the original AP aerogel series from audax cost about the same too so perhaps the price was about right. Who knows maybe the mission custom units had better motors, I doubt it though considering the end cost of the mission loudspeakers.
#9 |
http://www.audiolabga.com/pdf/SKO130-4.PDF
Hi, Well the 4 ohm version of the suggested replacements seems a very good driver, given they are £10 a pop. Lowish Fs, low Qts, good Xmax and flat response. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| FS pair of AUDAX HM170MN0 - MISSION 52-LFHDA | jazzy | Swap Meet | 6 | 23rd January 2012 11:56 AM |
| Mission Cambridge amplifier - Mission Power Amp Module 1 | Aleko | Solid State | 1 | 18th May 2011 01:14 PM |
| Wanted Dead Audax HD3P gold dome pizzo tweeters | spresto9 | Swap Meet | 0 | 24th June 2010 08:33 AM |
| Can compare Audax AM130 and AP130 | rinx | Multi-Way | 8 | 28th April 2008 07:21 AM |
| Page generated in 0.10647 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
