Is using a waveguide in MTM a good idea ? ( this one: Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories)
The tweeter is Seas NoFerro-650 with a low fs of 650 Hz and could be crossed at 1.600 - could it cross lower at say 1.400 with the WG? The mids are 17 cm drivers (Audax hp170MO). With the WG the CTC distance would be abt 32 cm (the WG is 15 cm high), without it abt 27 cm. Is this increased CTC distance (with the WG) creating a problem versus the benefit of a possibly lower xo point? Thanks. |
#2 |
The CTC between the 17cm drivers will be the problem. Below crossover frequency they will interfere with each other at rather small angles from axis.
#3 |
So better not to use WG and try to squeeze the mids as close as possible? What is the advantage of slightly offsetting the tweeter (thus allowing for an even smaller CTC), like the arrangement on the Sunflower?
#4 |
Offsetting the tweeter helps reduce prominent edge diffraction effects. Equal distance to each baffle edge compounds the effects, whereas having different distances to each baffle means that no 2 baffles can cause equal diffraction. The result is generally flatter response. The waveguide carries out the same purpose but does so even better than just off-setting the driver (no offset required with a wave-guide from my understanding)
I believe that in order to use the waveguide in an MTM, you'd actually have to do something like a WMTMW with little 2" full range drivers as the mids. Then CTC spacing drops to where a 1.6KHZ x-over is more feasible, the bottom x-over would then be somewhere around 500hz. Eric |
| is this a horn or a waveguide? | mondogenerator | Multi-Way | 146 | 4th September 2011 08:01 PM |
| Waveguide | kingfisher | Multi-Way | 4 | 23rd November 2010 02:32 AM |
| OB MTM w/ Dipole Waveguide | thadman | Multi-Way | 12 | 10th February 2010 07:56 PM |
| Measurements from MTM with tweeter waveguide | Few | Multi-Way | 2 | 12th January 2007 08:04 PM |
| dayton MTM or stryke MTM? | speekergeek | Multi-Way | 10 | 11th December 2003 06:02 PM |
| Page generated in 0.07699 seconds (73.21% PHP - 26.79% MySQL) with 10 queries |
