Old 30th January 2012, 09:33 AM   #1
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Default need advice - neo vs fe compression driver
havn't money, need 2 drivers..
can not decide - what to buy..
HD1050 - HF Compression Driver or ND1090 - HF Neodymium Driver
neo is twice as expensive..
identical diaphragm in both..
what about listenable difference?..
flesh flash flush
Old 30th January 2012, 10:20 AM   #2
Harmonic distortion may be different. Not sure which one would be better in that respect, though. I don't think that this would lead to audible differences. You're better off comparing the frequency reponse of both and picking the smoothest option. I'd probably go for the cheaper option.
Old 30th January 2012, 10:39 AM   #3
Flaesh's Avatar
overlayed FR from datasheets
flesh flash flush
Old 30th January 2012, 12:14 PM   #4
The Neo is more sensitive, but both have their own mild peaks. I'm not sure which one would be easier to work with. Will you be using a passive crossover? And which waveguide?
Old 30th January 2012, 02:18 PM   #5
Flaesh's Avatar
ordered Fe.
active cross.
hughes-like wg some time later....
flesh flash flush
Old 28th February 2012, 05:46 PM   #6
Flaesh's Avatar
rough measurements hd1050 in noname horn (like ph3220 http://www.paudio.ru/downloads/PH2420-3220.pdf).
noncalibrated mic - nady cm100. so don't know about reliability above 10000..
flesh flash flush
Old 29th February 2012, 12:50 PM   #7
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
IMO there are only a few cases were "going neo" makes sense.
1. Super drivers! There are a handful of woofer type drivers on the market, that are "nutty" as far as their capabilities are concerned. They take advantage of very strong motor structure designs from neo magnets to accomplish more work for less power than many competing options with Fe drivers. The problem is that they tend to be remarkably expensive. If space/weight is an issue at no cost limits, these are the way to go!
2. Weight! From a portability and ruggedness standpoint, a lighter neo magnet assembly reduces stresses on the horn and structure that the horn is mounted to when in transit. The lower weight of Neo motor structures, often combined with low weight composite or cast aluminum frames, can significantly reduce the weight of a total speaker system, which in turn, reduces the number of back injuries and medical claims
For permanent installations where space/weight is not a serious issue, I wouldn't spend an extra penny on a Neo driver personally.
Noob/Neo needing sound advice... kutnupe8 Multi-Way 3 10th September 2011 01:25 PM
Any opinions on Neo-fone driver? bluegti Full Range 13 4th July 2010 02:22 AM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
advice on a woofer to match fostex fe 103s kepa1 Full Range 3 13th April 2004 06:36 AM
Compression driver advice needed Jonathan Z Multi-Way 1 4th July 2003 10:46 AM
Page generated in 0.08793 seconds (78.50% PHP - 21.50% MySQL) with 11 queries
