Old 30th January 2012, 01:27 AM   #1
Salsero is offline Salsero  United States
Default woofer enclosure
I am considering putting together some 12" or 15" woofers in a separate enclosure and set them up as a typical subwoofer with a plate amplifier. My main application is music. I want to integrate them with my Tri Trix speakers in order to relieve the Tri Trix from the bass.
How should I go about making the enclosure? Are there guidelines, recommended reading, etc....
Salsero
Old 30th January 2012, 04:22 AM   #2
Default Look in sub-woofer category
You should have a look under the sub-woofers category...you may find posts similar to yours
Old 30th January 2012, 04:46 AM   #3
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
General rule of thumb is that if it requires a fork lift to move, you are on the right track
when designing a 2 woofer enclosure... slicemaster101 Multi-Way 33 5th April 2012 05:55 AM
AR-1 woofer - new enclosure? bentoronto Subwoofers 29 17th June 2011 04:02 AM
sub-woofer enclosure comasus Subwoofers 6 16th January 2011 06:20 PM
Small Enclosure Woofer h_andree Multi-Way 5 28th March 2008 09:25 AM
Woofer sound without enclosure gchrist Multi-Way 5 10th November 2003 07:32 AM
Page generated in 0.07246 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
